Poll: ** The AMD VEGA Thread **
On or off the hype train?
  • (off) Train has derailed
    Votes: 207 39.2%
  • (on) Overcrowding, standing room only
    Votes: 100 18.9%
  • (never ever got on) Chinese escalator
    Votes: 221 41.9%
  • Total voters
    528
Status
Not open for further replies.
They would love to go after the 1080 Ti or even Titan Xp but you can only use what is available in the tank.
AMD need to offer better value for money than you get with the GTX 1080 and all will be fine, if they don't people won't buy Vega just because it is expensive and made by AMD.
Under normal circumstances you are correct but with the predicted hashrates miners will take all the stock fast AMD could charge more and still sell these well. and Vega 56 will be like hens teeth.
Miners may take them but it will not do gamers or AMDs long term user base/market share much good.
I don't think they can though if they want to make money.
No magic bullet driver then.
https://videocardz.com/71771/final-radeon-rx-vega-64-3dmark-performance
Anyone spot the big problem?
Timespy is the only DX12 benchmark in the pic above and Vega 64 gets beat by a GTX 1080.
I wonder if the final drivers will give some additional scores.
Not really bothered about 3DMark scores anyway, Nvidia tend to do better in them with similar cards. I am interested in benchmarks from games.
This is the FINAL DRIVER...
Yesterday reviewers received their first RX Vega 64 samples, along with the final driver. Here are the final benchmark results of this new card, compared to GTX 1080 Ti (factory-OC), 1080 (factory-OC) and 1070 (stock clocks).
Note: for GPU score it doesn’t really matter which CPU is being used, but since some reviewers already started testing Threadripper and Vega, I thought it might be interesting to know where the performance of AMD HEDT platform sits.
Note 2: The clock speed reported by 3DMark is a peak clock, it may or may not mean that the card was overclocked at the time of testing.
Those scores are with the final drivers it states at the top of the article.
Having said that there may be improvements with future driver releases.
Thing is tho, you don't just put HBCC, FP16 and this DSBR hardware in a product and not use it at some point. Current games probably just do not use it. But future titles might once the hardware becomes available.
Also gives AMD something to okay with driver side moving forward.
ye they start using them in 3 generations of gpus FROM NOW.... Like always :/
Tbh there are already better scores for instance the frontier edition clocked just over 1700mhz is scoring way higher on the Graphics score. How have they got a hold of all these results in the first place. I doubt they are allowed to upload there scores at this point in time.
http://www.3dmark.com/fs/13215190
By the look of it that card is very overclocked, check out the memory clockspeed for example.
When you really push the cards 3dmark often gets the GPU core clockspeed wrong.:)
Here is a link to one of my Titans that is overclocked and according to 3dmark it is running some very odd clocks.
http://www.3dmark.com/3dm/17179775
I'm still taking those hashrate rumors with a pinch of salt, triple the performance of the Frontier Edition (which is essentially the same card as Vega 64 just with more VRAM) just seems too good to be true simply from driver refinements.
I really want reviewers to compare both AMD and nVidia cards on both AMD and Intel CPUs. This will hopefully highlight the nVidia on Ryzen issue to people as well.
I'm not having ANY problems on my NV + Ryzen combo... I had more with 290x+5820k all sorts of problems :/
The final drivers before launch, it's not uncommon for cards to gain serious improvements from post launch driver updates (I.E HD7900 series). OFC I am not saying that "will" happen, just that it has in the past.
Me neither.
Same guy on ultra. His memory is likely giving him some performance but he is only scoring 2 percent above the scores on there so the clocks are not pushed way higher. Looks like Vega clocks are getting read correctly.
http://www.3dmark.com/fs/13215192
Status
