Vivaldi 1.11 browser Released!
22 Sep 2006
Changelog from 1.10 to 1.11
New Features
  • Reader mode configuration (VB-29002)
  • Configurable gesture sensitivity (VB-30408)
  • Disable GIF animations by setting (VB-16320)
  • Optional Speed Dial buttons (VB-13687)
  • Update Vivaldi application icon and Windows installer backgrounds (VB-29965)
Fixes
Platform
  • [Mac] Add “Show|Hide” to View menu items (VB-28941)
  • [Mac] Gestures don’t work in Settings in a tab (VB-20258)
  • [Mac] Media crash (VB-29267)
  • [Windows] Context menu after gesture on SD page (VB-20743)
  • [Windows] “Open file with… ” message on start-up (VB-28604)
Address Field
  • Ctrl+Z does not reverse cutting content (VB-29135)
  • Improve search in URL field for drop-down filtering (VB-18556)
  • Paste and go does not work if the address bar is hidden (VB-29759)
  • Sometimes deleted characters get autocompleted (VB-29692)
  • Text selection cursor position is wrong (VB-29755)
Media
  • [Windows] Audio stops playing after a while (VB-29546)
  • [Windows] Audio takes ages to start up (VB-29699)
  • [Windows] Support video/mpeg4 (VB-27459)
  • Proprietary media served with wrong unsupported mime type fails to play (VB-29504)
  • Permission dialogs for media and notification fails to open (VB-29799)
Themes
  • Allow more fine-grained Themes color control (VB-29456)
  • Color changes does not auto-save when edited by keyboard (VB-29581)
Developer Tools
  • Restore the title of the undocked developer tools due to external tools (VB-29386)
  • Undocked developer tools do not work for internal pages (VB-29360)
  • Developer tools shortcuts are conflicting with Vivaldi ones (VB-27893)
Installer
  • Selecting standalone install mode does not always work (VB-30397)
  • Completed standalone install can open all user install (VB-30001)
Spatial navigation
  • Spatial navigation does not remember last position (VB-28965)
  • Spatial navigation cursor ↓ moves focus (VB-30263)
Tab bar
  • Tab bar disappears in fullscreen video (VB-29418)
  • Tab bar resize performance (VB-29510)
Other fixes
  • [Notes] Content does not display and can be lost (VB-29658)
  • [Bookmarks] Search in bookmarks does not find extra characters like brackets (VB-29588)
  • [Search Engines] Update moves modified engines towards end of list (VB-29828)
  • [Settings] Going from Display All to Keyboard doesn’t change the settings content (VB-29771)
  • Settings search is not working for Toolbar (VB-29332)
  • Search nicknames should be lowercase (VB-30642)
  • [Speed Dials] If custom thumbnail has been used and cleared, it does not revert back to the generated thumbnail (VB-29384)
  • Accept text/plain as drag type for web panels (VB-29303)
  • Back button drop-down does not appear on Speed Dial (VB-30052)
  • Changing extension icon problem (VB-22413)
  • Find in Page covers scrollbar (VB-29921)
  • Have Popup in Tab off by default (VB-29742)
  • Hidden control has focus in App Updater (VB-29273)
  • Missing Windows 8 icons and tiles (VB-29965)
  • Permissions are not asked for when a permission is used (VB-29930)
  • Provide a way to unfocus a select field by keyboard (VB-28140)
  • Sort typed history based on time, not length (VB-28939)
  • Suppress autocompletion if typed matches domain or ends with a slash (VB-27956)
  • The update notifier should check for updates when it’s launched (VB-29339)
  • Unread tab indicator contrast adjustments (VB-12813)
  • Vivaldi does not update search engines nor does it add new ones on previous installations (VB-28151)
  • Vivaldi installed on a virtual drive cannot be updated correctly (VB-29793)
  • Web panel context menu (VB-23465)
  • Wrong extension behaviour between private and non-private window (VB-28010)
  • % becomes %25 when searched from address bar or field (VB-30266)
  • Updated translations
  • Updated Chromium to 60.0.3112.91
https://vivaldi.com/blog/focus-on-accessibility/?hl=en-gb&version=1.11.917.39&os=W10.0.15063
You want speed then this is the browser for you :) .
Meh, yet another Blink engine with a different UI...
Don't knock it to you actually try it for awhile, it may be Chromium based, but has a lot more customisation then Chrome and developed by some of the old Opera developers.
I can't fault it on stability and speed, I wish Firefox was as stable.
