It's the lack of tearing that makes G-sync (same for freesync) invaluable to me. When I had a 60hz monitor even with capped fps and software adaptive V-sync there would be some tearing which would irritate the crap out of me. The other option was the lower fps/stutter associated with V-sync. Even when running well below 144hz, around 60-80 G-sync ensures no tearing and that is beauty of adaptive sync in my experience.
The problem is the voltage and power settings were carefully selected by AmD to.ensirr sufficient yeilds at specified clocks. So.while it is possible many Vega chips could be powered.doen and maintain similar.performance not every chip can.
You have the same with Pascal cards. Most of them you can undervolt,drop power, increase clocks and still run.lower overall.power at equal or higher performance.
You can hand test individual chips and bin the best and worst. AMD did this with the Nano ecting the best chips that would run at the lowest voltage. But it is expensive and takes time to stock pile the better performing chips
Thats massive drop in power from Turbo to Balanced, yet it only equates to about 2/3 frames difference, so id just stick to Balanced.
That is crazy, who in their right mind would do that talk about shooting yourself in the foot again.
In fairness, the liquid Vega was (at launch) the same price as a hybrid 1080, and £150+ cheaper than a hybrid 1080ti.So the liquid cooled Vega is a ridiculous purchase, it costs the same as 1080Ti, but is around 30% slower hmmmm
If they perform on par with equally priced (at Vega launch) Nvidia cards but offer additional features that some people want, doesn't that make them a good card?Sadly I do not see AMD lowering prices, as they will likely be selling them as quick as they can make them. Not because they are excellent cards, but because there are a lot of people with Freesync monitor's finally looking to upgrade
If the 56 was fast enough for someone, it looks good, in fairness. But if I was going to get anything, it would have to be faster, and preferably better value - so still nothing for me on the whole high-end gpu market! Maybe next yearI just don't get why anyone would buy them, even those with FreeSync.
megasadface
I like the cards, problem is they are late and pricing as a result does not seem very good. If you watched the Adored review, right at the end he quoted Anandtech guy. There is not such thing as a bad graphics card, only bad pricing. Now if I want to buy a Vega card right now, can you seriously tell me the pricing is good and therefore I would be getting an excellent card? Nope don't think so.If they perform on par with equally priced (at Vega launch) Nvidia cards but offer additional features that some people want, doesn't that make them a good card?
It doesn't seem to be that way from the reviews I've seen. To be fair though it's a 300W or more card.Oh I didn't mean it wouldn't be loud, just that the better fan/heatsink than the 1080 dustbuster means it's not going to be any worse despite the extra TDP.
And the point I was making was you can't just compare a AIO card to random cards, you have to compare it to other AIO cards otherwise what's the point of comparing the AIO instead of the reference. And at it's original price before retailers went trolololol the Vega AIO was cheaper than a 1080 AIO and £150+ cheaper than a 1080ti AIO. It was a good deal, but not at £780 haha.The point I was getting at was that even with an AIO it gets nowhere near a similar priced 1080Ti and then only just about beats an AiB 1080 costing over £100 less
I see, in honesty my prediction was based on the Vega reference fan being the same one as Polaris, which was noticeably better than the one in Pascal. That combined with both cards having vapor chambered heat sinks lead me to assume that even with the extra heat of Vega it would still be comparable noise wise as it can move significantly more air at the same volume.It doesn't seem to be that way from the reviews I've seen. To be fair though it's a 300W or more card.
