ROFLMAO at new Hitler video.
It's class, but someone needs to do the laughing Spanish man!
Just a note, the card does 1700mhz on the clock dropping the voltage control to 1080mv going to be fun on water this thing
Ok this is strange..I'm just running some benches here with GPU-Z and wattman open. With my frequency percentage at 0% so default clock, my core is locked at 1630mhz. Ive just done 2 solid runs of heaven and the clock has not budged at all from 1630mhz. I can downlock/overclock it which I then see a difference in the reading, so I know the reading is correct ie the reading has not stuck at 1630mhz, but I thought this would throttle. Sitting at 83c (which I'm really not happy with) with a 2500rpm fixed fan speed for the benches.
*GPU-Z showing 1630MHz stock clock*
I use a rm650x with mine , it didnt like my ryzen 1700 oc'd to 3.9 with vega, but everything is fine oc'd to 3.8 so farI'm having some real problems with my Vega right now - System keeps rebooting when in games (Especially battlefield 1) and after a longer period of time when stressing it with synthetic benchmarks like fur mark and uniengine. It isn't as bad when in power save mode, but still does it at some point.
I suspect it is my power supply crapping out, which I find odd because it's a good quality one - EVGA 550watt Gold Modular. It's rated for 540w on the 12v rails so I don't see why it feels out of spec. I have a power meter running and in balanced mode with CPU loaded and GPU loaded to the max, I see no more than around 400w being pulled. Maximum I have seen in turbo mode was about 460w total system load. In power save total loading in game goes down to less than 350w.
It seems odd, it's not hot to the touch either...
Anyway, I will confirm this theory soon as I have an Cosair rm650x on the way. If it does fix the problem I think EVGA will be getting a message from me!
and blowersSeeing a few liquid ones in stock elsewhere, surprised ocuk has none in today.
At current prices it's almost worth spending a little more on the liquid edition one. At least temps are easier to control and it's the fastest one available.
Maybe the retarded miners card. Even undervolted it still draws more power than the GTX1070 while providing no extra performance, unless AMD launch it at £325 or less you would have to be mad to pick it up for crypto over a £350 GTX1070.56 will be the miners card If undervolted
1070 is 26 vs 32. Most farms dont care to much for power draw - least in china - EU yes- but guessing some will have Renewable sources to power the rigs.
If your a uni student going into halls in Sept. you can just run the 56 for 9 months 24/7
1070 is 32 (I get 29MH/s out of mine but I'm dual mining SiaCoin). My rig with 6x1070 pulls 1030W - just to give you some idea of perf : power
Anyone messed around with undervolting yet in a controlled manner like the dude on Gamers Nexus?
