Why the 120 FPS limit?
There's really no difference between 144FPS and 120FPS. By that I mean I cannot tell the difference and have experienced many games and monitors over the years, including decent CRT monitors.
In limiting to 120FPS:
- Temperatures are lower
 - Graphics card is quieter
 - If you have a G-sync (or Freesync) monitor, you should at least IMO limit to 143fps so it stops the FPS hitting 144 now and then and disabling the sync causing a bit of lag and tear.
 How can a motherboard be "Gamey".
