It does strike me as strange that AMD would mess up the release day drivers this way. I mean they've never messed up a GPU release before![]()
LOL, remember the HD7970. Was a good 3-4 months before we had stable drivers.
There's only so many bugs you can find with internal testingSurely with about 80% of them working on the Vega drivers (which they were saying for months and months), they should be fine.![]()
.Not sure about all, but it was not working for me and others on 17.8.1.Hi Matt, are you saying voltage control is not working at all with current public drivers? If not that will explain why I am getting no reduction in temps when dropping volts? Is it not working in WattRool or Wattman?
Thanks
I've honestly got no idea. We don't recommend or validate bios flashing period, so it's most likely not recommended or supported. That's not to say it may not be possible though...I heard that potentially we will not be able flash a liquid bios to a air card with custom block. Do you know if this is true AMD Matt?
From what I read you can flash an "official" BIOS, like the ones that come as standard on a reference or AIB card, however if you flash a BIOS that's been modified/altered in any way it won't be signed by AMD and the card will not initialise. This is apparently part of the Windows Secure Boot standard MS introduced with W10 and will be the case for all GPUs going forwards (doesn't mean to say a workaround/hack is impossible).I heard that potentially we will not be able flash a liquid bios to a air card with custom block. Do you know if this is true AMD Matt?
As long as the registry power tables don't get fixed I don't mind; just don't screw over people who replace the blower![]()
Flashing another GPU VBIOS to another may not works. Sometimes the ASIC has a fused ID, so it still is distinguishable. For example flash a 290/X to 390/X it still will be identified by driver as 290/290X. Let's say the VEGA 56 AIR card has a fused ASIC ID and you wanted the higher clocks/PL contained within VEGA 64 AIR it may not work. Then also as you have unlocks possible in the past on Hawaii/Fiji that won't be possible.
So far all is confirmed is any modified VBIOS is no go, regardless if you use WinOS or Linux.
Only one member on OCN so far has succeeded to use Linux. Stock VBIOS but kernel is modified to load an edited VBIOS. This is similar to the registry hacks at present for WinOS.
The registry mod is a loop hole of the drivers AFAIK, can be closed if need be. What essentially is being done is what MSI AB 'Extend Official Overclocking Limits" would do, that option in MSI AB places a snapshot of VBIOS in registry, then basically SW/registry version of 'tweaks' the driver sees as being what the firmware would tell it for xyz parameters.
From ~7xxx series a digital signature in Legacy section is used. This the driver referenced at OS load (Linux didn't). Now besides the driver referencing it the UEFI/GOP module within AMD VBIOS must validate legacy section when mobo boot in "pure UEFI" mode is CSM: Off.
The driver can have signature check removed. For example they did that on 7xxx and it made it possible for bios mod. Initially Hawaii also had driver checking and then it didn't.
Now a modified VBIOS like said before will fail validation by UEFI/GOP module, when mobo is set with CSM: Off (ie pure UEFI mode), even if Secure Boot is off. But there is a work around, a modified UEFI/GOP module inserted in VBIOS will not check signature in Legacy section of VBIOS.
But now AMD have gone a step further, VEGA has HW which validates the VBIOS. SO now VBIOS has to really have correct signatures or it just will not work.
Has anyone looked at what Vega clocks at while browsing/youtubing ? And the power consumption ? Curious because they talked about it being able to clock in 1mhz increments with a lowest clock at 27mhz (desktop not moving mouse), I'm wondering if the average browsing power consumption is somewhat lower than anything Nvidia offers, maybe offsetting a little bit the high gamin power consumption.
I'm uploading a BF1 4K Ultra video, definitely able to run max settings at 4K 60FPS on stock Vega 64.![]()
I'm offended that you would think that Mr Gerard.Hopefully not an indoors video as that's cheating![]()
It's outside, it's the map with the castle type thing. I hate that map, so i may do another one with a different level before long.
