- 29 Jul 2013
Can be turned on in the battery settings.The 76% battery indicator, does this come as standard or still a 'hidden' feature?
That would be a downside of buying a SamsungAnyone know when I can expect O on my S8+? Done some searching and people are saying as late as Feb 2018?!?!
Yup... Annoyingly I got rid of my Pixel XL for the S8+. I'd be blitzing the Oreo right now if I hadn't.That would be a downside of buying a Samsung
The version you've all got on the beta may not be final.
The images aren't on the Google Dev page (still showing 7.1.2 as the latest images) and things like the Easter egg haven't been updated.
Just a theory of course but I think this is an RC and the final build will come a bit later.
Surprised no one is talking about the background app limits that have appeared in Android 8. I'll have to dig into it further, but on the face of it it looks very similar to iOS background app limits, which have been lambasted over the years for not allowing the iPhone to 'multitask'.
Personally I think it's a big plus that Google will start properly controlling background apps in this way as it should result in better battery life and a better user experience for users.
Seems they are taking this seriously
https://productforums.google.com/fo...eDphsoOJ4;context-place=forum/phone-by-google
Was gonna post in there but it says "only issues after getting the Oreo update" and I've had the same issues on Nougat. Really seems like it might be a hardware issue.
Well I hope it isn't the final version as bluetooth is STILL a mess. Not working in the car again. It did start working once after I first paired it, but same doing the same old tricks.
Confusingly, any and all mentions of beta have been removed. Confused as to what's going on.
What I will say, is that if spotify doesn't start working soon I'm switching back to a phone that works properly.....and of all my testing it leaves me a single choice of an iphone (which I hate).
Suppose I could buy an ipod touch
:edit:
ok, so it looks like it is final?
My version is opr6.170623.012 which is the same found here
https://developer.android.com/about/versions/oreo/download.html
Yup... Annoyingly I got rid of my Pixel XL for the S8+. I'd be blitzing the Oreo right now if I hadn't.![]()
In Oreo isn't there support for many different types of bluetooth codecs?
Try a different one.
Its a never ending cycle really.. Every one jumps on the latest and greatest Sammy flagship. Then when the next major Android version is announced suddenly there is regret buying the S8. This again will be the case for the S9 and Android P and so on and so forth..
Luckily I still have my Pixel XL with me so I get the best of Android has to offer
