Hi All,
Not quite sure where to put this but I suspect it maybe a mobo issue but not sure. Basically running games on the ROG Zenith Extreme / 1920X / 1080 FE SLI (AIO watercooled - both CPU & GPU's) / Samsung 960 EVO NVME - running the first game I came across - WOW - and I'm getting about 1/2 FPS I was getting on a 5930K / 1080 FE SLI and about 1/3 less than a 4970K and 9 series titan X (have a very set routine for testing FPS, so the variance should be minimal).
3d mark spy hunter gives about 12,000 SLI and 7,000 single card - seems well below average.
The system feels sluggish even in windows 10.
More details -
- 1080 FE in SLI with Gsync at 100Mhz to Asus 3440x1440p monitor
- Tried all BIOS revisions including beta 0503 (0211 doesn't work due to requirement to use DIMM2 and SLI)
- Cooling and temps are fine, nothing *appears* to be thermal throttling
- RAM is 2133 in bios, can push to 2400 but it becomes unstable
- Tiried stock 3.5 and o/c 3.8,3.9 and 4.0 - whilst all are stable the same problem persists
- brand new install of Windows 10
- latest drivers from Asus website
- GPU's running in PCIE 3.0
Things I'm going try -
- Another game (obviously) just downloading Doom which was a very solid 100FPS
- Unplug the power of a GPU so it uses a single card only
- Revert to a SLI bridge - I was using a EVGA HB SLI bridge but got the more aesthetically pleasing ROG HB bridge to sync with the mobo (grasping at straws)
Any other things I could try / check? Is there some AMD tools I should look at to check things, seem to recall some people mentioning them in reviews - has anyone has to do that?
More details -
