Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
iPad Pro 12.9 256gb to go alongside my MacBook Pro. I’m now seriously considering swapping my android phone for an iPhone as well![]()
I have the 10.5 - it was worth it for the screen alone - and I thought the 12.9 was a little bit too big for something that's used as a tablet a lot of the time.
My cats sometimes do that for me so it's already covered, but thanks for the pro tip!Thanks dude. Getting there, just got to sort out all the cables. I have some trunking arriving Monday, and need to extend some cables or work out how best to arrange them.
Make sure you defecate on your floor though. It adds to the ambiance of the place.
Mirra arrived, but it has some damage to the seat back so they're sending a replacement. So much nicer than the old dining chair I've been on. My back is already thanking me.
I got some office skate wheels for it, too. They're very smooth on my tiled floor over the standard wheels.
Now my Logitech K750 has stopped working properly. The input lag is unbearable. I can't deal with that. Then it just doesn't work. Need to contact logitech. Luckily Ive got another keyboard coming, though wired. Will see what it's like.
Just tell your little one that you're trying to steal them, I'm sure they'll be more than happy to lend a handHa ha I need to spend some time adjusting them on the wall mounts, it's a 2 man job though as the weight when you're adjusting is really hard to manage. I've tried alone and it's impossible!
