Caporegime
 - 8 Jul 2003
 - In a house
and still they come, recall ?
Switch to the left is default bios and to right is secondary bios (which basically is the same power profile as for the default bios on the Air model)
Has anybody received their "pre-order" from the unlucky bunch that missed out on launch day?
Those waterblocks look superb.
Weirdly if I set the card to power save mode I get no issues at all. I am running a EVGA 850w P2 PSU so doubt it will be that.
Basically where I'm at as well. I have a new PSU (Corsair HX1000i) due to arrive today to replace the current RM750 which is a few years old now, and only an average PSU to begin with. Want to rule that out before I jump to any conclusions. I suspect my PSU is borderline as the card seems to be getting increasingly sensitive to the point that it is now only fully stable in power save mode, whereas balanced was fine initially.
Nice one Shanks. Now if we can just add Lemar to that order...VEGA 64 Ref ordered £470![]()
With a little bit of van dijk on topNice one Shanks. Now if we can just add Lemar to that order...![]()
There have been a few duds about but mine is rock solid - only crashes when I've been pushing the clocks with Benchmarks such as Time Spy. I have a very stable 100Mz overclock on the Memory and the core clock boosts up to 1750. Not a single crash playing games at either of the stock profiles or with the memory at 1045Mz.Does anybody have a card which doesn't crash? I wanted one of these, but now... i'm not sure.![]()
That's as far as I got it to go with a bit of an overclock on the core, I didn't actually try it past that leaving the core clock at stock - I'd spent pretty much all my time at the computer over the past week running benchmarks only for everything to change with the release of each driver so decided to start gaming again and stop using all my computer time running benchmarks. Not bothered about the watts savings at all but if you guys are getting more then I maybe run another wee test and see...is that all your HBM can do? you can probably get the same performance at 50 less watts!
