What resoloution are you expecting to play at ? self build or prebuilt and do you need windows ?
What!p-p-p-p-p-p-powerbook.
It'll be always the same speed. And run new applications just as well as very old applications,.
Hi
Could you spec me a gaming pc that will last a very long time. Not a over the top graphics card. All components that have a long life.
Price £550
Thank you
1060 for 768P @ 60Hz? LOL. Horrible. No offense.a bit over budget, no case but you can make one out of cereal boxes and sellotape.
My basket at Overclockers UK:
- 1 x AMD Ryzen 3 Quad Core 1200 3.40GHz (Socket AM4) Processor - Retail= £98.99
- 1 x Asrock A320M-DGS AMD A320 (Socket AM4) DDR4 Micro ATX Motherboard= £47.99
- 1 x XFX XT Series 400W 80 Plus Bronze Power Supply= £34.99
- 1 x Toshiba P300 1TB 7200RPM 64MB Cache High Performance Hard Drive (HDWD110UZSVA)= £38.99
- 1 x Team Group Vulcan T-Force 8GB (2x4GB) DDR4 PC4-19200C14 2400MHz Dual Channel Kit - Grey (TLGD48G2400= £69.95
- 1 x Palit GeForce GTX 1060 Dual 3072MB GDDR5 PCI-Express Graphics Card= £188.99
- 1 x SPEEDLINK Jixster Ambidextrous Mouse, Black= £5.99
- 1 x MARS Gaming Hades MKHA0 Gaming Keyboard - UK Layout= £8.99
- 1 x Asus VS197DE 18.5" 1366x768 TN LED Monitor - Black= £65.99
Thank you very mucha bit over budget, no case but you can make one out of cereal boxes and sellotape.
Thank you very much'
Managing expectations' springs to mind here
Gaming longevity with a low budget like yours isn't really possible, although it does depend on what you mean by 'a very long time'.
- 1 x Intel Pentium G4560 3.50GHz (Kaby Lake) Socket LGA1151 Processor - Retail= £64.99
- 1 x Asus H110M-K Intel H110 (Socket 1151) DDR4 Micro ATX Motherboard= £47.99
- 1 x Kingston 240GB SSDNow UV400 Drive SATA 6Gb/s 2.5" (7mm height) Solid State Hard Drive - (SUV400S37/2= £79.99
- 1 x Palit GeForce GTX 1050Ti StormX 4096MB PCI-Express GDDR5 Graphics Card= £128.99
- 1 x XFX XT Series 500W 80 Plus Bronze Power Supply= £42.95
- 1 x Raijintek Arcadia Mid Tower USB 3.0 Case - Black= £27.95
The CPU is out of stock at the moment but is a good, albeit budget workhorse. The weak point is obviously the GPU
