The LC 64 pain is real.
Aye sure they're grand, no probs with them at all, they only seem to excel at dying quickly if on here is anything to go by.
How much does one of those cost. I dont have this problem as my monitor is so ancient its just a handy excuse to upgrade it to something with modern connectors and use hdmi meanwhileThat's Plan B if the active DP to DVI adaptor doesn't get here tomorrow.
Actually, he's referring to infinity fabric on VEGA, somehow this is being pass around as the entire VEGA.Interesting stuff from Raja on Vega not being optimised for gaming yet. Says there will be a proper consumer Vega optimised in the future. Supposedly down to the infinity Fabric.
https://www.eteknix.com/amd-vega-no...l&utm_source=facebook.com&utm_campaign=buffer
From the guide posted, it actually goes upto 300 which is useful in Csgo as thats the general game limit an often wanted maximum. I'm using the game profiles as that will actually save me time as steam cloud never sticks properly/fully for meFRTC can be set to values between 30 and 200 FPS and works with DirectX® 9, 10 and 11 3D applications.
they have new software in the works, when it will land who knows but here is a sample of what to expect from it, my guess is that the next big driver update for vega will be attached with the release of this
Hi All, managed to solve the Crysis 3 frame rate problems - just turned on triple buffering for opengl on the AMD driver panel and now getting solid 60fps with the exception of a couple of frames dropping very very rarely and un-noticeably
Set at FXAA and max settings on a 1440p resolution monitor - the game looks stunning...
Using HWINFO64?I need HELP guys. I got the RX Vega 64 AC. Driver 17.8.1, a Ryzen [email protected] and 16GB running at 2933mhz. When I open a game the video card stutters every now and then for a second or two. Also, when it stutters, I can hear a stuttering sound inside the case. I can't identify where is it coming from. It happens in Balanced, Turbo or custom. Doesn't matter the power limit %. The whine starts as soon as I open a game. The GPU temp is below 60c while playing RL, so is the HBM Temps. The switch on the card is on the left side, towards the back of the case. Game goes from 144fps to 90fps stuttering and then back up. It happens in Rocket League, PUBG or any other.
You want it on, it improves benchmark scores and adds a small boost in some games. No reason to not have it on as there are no ill effects from enabling it. Just set it to the minimum amount allowed.Sounds bloody confusing to me. Dont have one brand name for professional and consumer products even if its the same chip underneath.
I presume I dont want HBCC on for most games, I have 16gb but dont think it'll help. Fast ddr4 memory actually but I have a no fun xeon locking it to a low speed
Nice, sample source?
Not mine just thought it looked good
Disable VRM voltage monitoring in HWINFO< + update to the latest build to resolve stuttering.The stuttering in games happened to me a few times when I had hwinfo monitoring running. Turned it off, all good, stuttering gone. At times, though, simple alt-tab can fix it too, as freesync can be bugged in some games like that.
