That's the thing, I want the colour scheme without looking like a disco or over the top. Will check bios for the pump speed in a minute.
Think Phanteks is on to a winner with those covers, getting to have your fan of choice with a soft RGB, seems on clear/frosted plastic they shine out more . Orange glow on yours and should be a killer and just illuminate the case slightly .
Worth pumping the front intake fans to as fast as possible that your comfortable with sound wise. Either allow them to run like that 24/7 or set up a good fan curve
I have silent wings so pretty much run them at 80% 100% of the time as soon as theirs any load what so ever .
Just noticed you've got two usb running from inside to the out usb ... Is this from the front box ?
If so, by a internal USB to external USB cable or You split one
