- 25 Nov 2011
- The KOP
Vega just eats through MSAA like it's nothing
8x MSAA 1440p Ultra
Res was 1440p, Mem at 1040 iirc. FH3 was maxed out settings x4AA, unlocked framerate.
Was late when I did it so might re-run again if I get time, also forgot how nice the game looks at times and so want to try it out at 4K on the TV at some point.![]()
@shankly1985
Did another quick run to confirm mem at 1040. Still playing about with my card settings for clocks, power etc so will probably tweak this further.
Also hope to put something like an Eiswolf on it at some point, so not spending too much time on it at the moment.
Well that's AMD's fault. We even had AMDMatt here saying that if it crashes at normal clocks with +50 percent power, it's faulty and should be RMA'd. Just goes to show how the drivers and hardware are intertwined and if one doesn't work, then the other is useless too.
Too bad so many people sent them with RMA when in fact they might have been ok, just drivers weren't... Waste of time for these people :/
Thanks for doing this, I just can not get my memory to max out unless I put more demand on the memory like 8xmsaa very strange
Watched the video when he uploaded it. It's one thing him saying about altering the powerplay in registry, but how do you do that lolDo not think it will be worth it. The voltage to the HBM2 is the same. The only "upside" is the higher power limit and as you undervolted yours, I do not think you are currently running into any power limits? The registry hack with the power tables seems like another option to increase the power limit if you really want to. Source the almightly buildzoid: https://www.youtube.com/watch?v=SlpkmPEYTGE
- Open 3DMark and while it loads the menu, move mouse frantically over 3DMark window till it is done loading (Tab that should be loaded is home with the Timespy background)
- Report back if your system freezes
Trying to figure out if the issue I am having is a hardware issue with my card (RX Vega AC) or that it is just software instability. If anybody would be willing to check would be awesome! Thank you
Issue persists with drivers 17.8.2 and 17.9.1. Taking out the Vega and using the iGPU fixes the issue even with AMD driver installed.
Steps to reproduce: (Only for RX Vega owners)
- Install 3DMark Advanced edition
- Repeat for 10 times:
It seems my system locks up when the fading animation is going on in the menu and so far I cannot find any reports of the same issue.
Been keeping an eye on my memory too over the last few days - although my card is an AOI, it is locked at the 1080 I have it set to.Thanks for doing this, I just can not get my memory to max out unless I put more demand on the memory like 8xmsaa very strange
no issue here but with an SSD it loads pretty quick so not sure if that affects things?
Hate to ask but....how in the blue hell would anyone even manage to create that oddly specific scenario in the first place?
Is anyone experiencing Memory clock speed dropping?
I not sure if my GPU has an memory fault or am I missing something?
On the R9290 when gaming memory was locked to 1250 but with this RX Vega am seeing speeds drop from 945 to 800 to 500 even has low as 167
Can anyone else monitor GPU memory while playing some games please and tell your results.
Thanks
Magic! Internet! Nah, was benching for stability with 3DMark and noticed crashing on startup and "Gathering System Info". It caught my attention I was moving the mouse everytime and I tried to break it on purpose; with success! As you can gather, having to restart the system, open all monitoring tools, load 3DMark gets pretty frustrating when your system crashes every 10th time so I wanted to know what was going wrong. Seems to be the card.![]()
Chalk up another one!![]()
My memory is maxed out to whatever I set my last P state for memory when playing Doom without VSync, 3DMark Firestrike or Unigine Superposition. Might try any of those options to check?
EDIT: You sure your aren't frame limiting the card in any way?
Benchmarks seem fine, I only really monitored Forza so might just be that title.
How do I know if I frame limiting?
