At very high volts well outside of the efficiency range of the fab process yeah. No doubt everyone could get 4GHz if you were willing to pump the XFR 1.5V+ through your CPU constantly. Realistic all core speeds are 3.9 at reasonable volts. With the fab update that all core speed should shuffle up a few notches while remaining in the 'reasonable' voltage range.
Well with 10% more performance that 4Ghz would be 4.4Ghz at 1.5v or probably a little less from using 15% smaller transistors. Will be interesting to see.
