Garage filled car with diesel. It's not a diesel.
Caporegime
29 Aug 2007
Auckland
Morning all,
I stopped at services last night and the attendant put 55 litres of diesel in my petrol Legacy. Chap came and did the fuel evacuation piece, saying that there'll be no material damage. It's an old car so I'm not worried about it blowing up/breaking down for re-sale concerns but is there anything I should be wary of in terms of it playing up? The engine wasn't started before the diesel was removed and the car started perfectly and drove home ok as well.
Drama in a teacup or should I do anything further?
You'll be fine. :)
If you tried running it on a tank of diesel, or if you were running a diesel and stuck some petrol in, then you could/would have problems.
If the fuel was removed and the engine not turned over, then refilled with petrol I doubt you'll even notice any rough running and you'll be fine.
People don't usually put diesel in a petrol car by accident, due to diesel pump nozzles being larger in diameter than a petrol nozzle and so not fitting in the tank filler neck, what kind of mickey mouse car do you have? lol.
Some diesel in a petrol isn't a massive problem, it might smoke a bit since a petrol engine won't burn it properly due to lack of compression. It's the other way round that can be a disaster.
my mum stuck 70 litres of petrol in her tdv6 discovery, drove 3 miles before it conked out.
surprisingly a £350 bill from the local LR specialist and its back operational as it was.
I did feel sorry for her, she had a swift sport for 7 years before so just a habbit
