again apologies for the poor pics , will try and get some nice ones tonight with all three in!
Must say i prefer these to LED strips which arent diffused - why no one has done a diffused LED strip whether in a casing or film applied i dont know why!
These spread the light nicely and was surprised with colours like light blue actually illuminate the case quite a bit- specially if you've scene the space in the PC-O11!!!
I personally think they have missed a trick here though, but is understandable as its the first product of its kind on the market.
would have liked to have seen 240 and 360 molded covers - one single piece instead of having to use individual ones with RGB connectors linked in a daisy chain with only one lead out of the unit.
If theres any way OCUK can give feed back to Phanteks- please let it be this!
Might fit the bill for the Skaven rig!
It matches and covers the Pure wing fans nicely! I will say Bequiet doesn;t include 35mm m3 like alpha does, and ones supplied are UNC with halos that not all rads use
will say and i cant remember, if the silent comes with 5mm short m3's. use that to attach the fan to the rad with the Fan hole closest to the rad and using a thin screw driver to get through the top most hole. then use the case screws to screw the fan/rad unit to the case
or just order 4 35mm m3 screws
