NP
I don't think you have bad RAM
. I will do a 2933MHz Dual channel run, from what I have seen what 'we' get as dual channel benches double speed at quad channel for Mem Read/Write/Copy. Compare Sicness's post with my runs
. He has Flare X but the Trident Z I have use same PCB/RAM IC, we have same CPU/mobo, etc.
Note: CPU is stock in runs below, even latest beta of AIDA64 still shows incorrect RAM timings, runs done with last beta, latest is same still for results.
3200MHz Dual Channel - The Stilt Fast preset for Samsung B die, single sided RAM, 1 dimm per channel config.
3333MHz Dual Channel - The Stilt Fast preset for Samsung B die, single sided RAM, 1 dimm per channel config.
3466MHz Dual Channel - The Stilt preset for Samsung B die, single sided RAM, 1 dimm per channel config.
3466MHz 2T Dual Channel - The Stilt preset for Samsung B die, single sided RAM, 1 dimm per channel config.
Ref this post by The Stilt and view the screenies above, aim to tweak timings and see where you get
*** edit ***
Another tid bit that I forgot that will quicken your tweaking
View OP here, go to section RAM Info / Data Fabric ... > The Stilt's DDR4 Timings, there scroll down and you will find a link to a post by The Stilt with Hynix AFR and MFR RAM IC (you have AFR), these should work. They are for single rank 1 dimm per channel
Even if you are using quad channel Threadripper is 2 Ryzen memory controller supplying 2 channels each, so essentially your 4x 8GB SR is 1DPC.
*** edit ***
