Vulkan and Direct3D12 require the game devs to implement multi-GPU support, I'm not aware of many that actually have made that effort. Ashes of the Singularity is the only one I can readily think of.
I really shouldn't have flashed my Vega56 with the bios from my mates 64, it's got me back to playing about with the card. I noticed that if I want to keep it at the 1600 clocks you simply can't keep the fan profile low and if you let it crank it's just far to loud.
My card seems to be able to hit 1620 on the core and 1100 on the memory without issue but to keep it there my ears take a pounding even with an undervolt. I don't want to go full water but have an aio on the cpu so had a look and found that alphacool do a aio for Vega. I couldn't resist and bought the eiswolf 240 aio. Should be with me in a few days![]()
so it wont fit in slimmer cases but there are plenty to choose from for not that much money.Solution seems pretty clear to me. Get a good aftermarket cooler and use it. Doesn't have to be an AIO as a good air cooler would do wonders. Its how i tame the thermals on my 1080ti using a Prolimatech MK-26. Now that specific air cooler might be a little crazy for some as it is huge in all directionsso it wont fit in slimmer cases but there are plenty to choose from for not that much money.
guess I will find out in a week or so.Might be too large.
RGB strip is just used to light the case, and the motherboard accents are always on red for AMD. Coolant will be changed out for red stuff soon, might get a monoblock for the CPU/VRM and i will probably get a larger reservoir tube
Crikey,
I decided to flash my 56 bios, I must have picked a liquid cooled 64 bios....GPU said it was at 1730 on the core!
Decided not to bother running that and reverted back to normal 56 BIOS, I didn't fancy burning my house down![]()
What temps do you get with just the one rad?
Crikey,
i did the same, dont know why but my games just felt as they were running better on the 56 bios, i got a higher score on heaven with the 56 bios overclocked and undervoltedCrikey,
i think with AMD's new boost system if there's instability it lowers clocks randomly then increases them again, so if something aint 100% right with the GPU games will feel stuttery? I just tried a 3dmark run with the Vega64 liquid bios and it was only loading the core 50-75%, then hard hung too. On Vega64-air now still doesn't seem right.
what are the temps like on air64?
Pretty sure the only gains on air 64 are higher voltages right? Because web can't overclock the memory voltages atm I suppose that's the only real advantage to t he 64 bios.
ah yea forgot about that to. makes sense. although ive had mine running at 1700 undervolted boost and 1722 in wattman on 56 bios, so perhaps no need yet to flash.temps for me are exactly the same due to watercooler. Voltages arent the main improvement, its the higher power limits. With the standard bios you would hit 220-240watt max and it would start underclocking the card. The 64bios seems to be peaking at 300watts. So with the same voltage my card can hold 1663mhz vs about 1580mhz on the 56 bios
Is there an undervolting guide floating about that someone can point me to?
