Caporegime
- 9 Nov 2009
- Planet Earth
Also, things might be closer in terms of bottlenecks now. But what about the next lot of GPU's etc? Phenom II wasn't *too* bad when it launched but it didn't hold anywhere near as well as the i7 920.
People always seem to forget this. It's all about grunt left in the tank, however this time, if games do heavily make use of high levels of multithreading, then the Ryzens will be pretty good then.
Except the Phenom II was priced similar to the 45NM Core2 CPUs which were its main competition:
http://hexus.net/tech/reviews/cpu/18149-amd-phenom-ii-x4-955-black-edition-back-bang/?page=12
Look at the pricing table,and more importantly the X58 motherboards were massively more expensive and they required expensive triple channel memory. Its a moot point if it lasted longer,since by the time you factored in the costs of the expensive motherboards and DDR3,a few years later you could have gotten a £150 Core i5 2500k and a motherboard,etc for not much more,especially if you factored in the cheaper price of the Phenom II X4 and Core2 quad. You could run a Phenom II X4 or 45NM Core2 quad off a £80 motherboard if you wanted to overclock a bit with some much cheaper DDR2.
I mean that does not even consider the fact the Phenom II X4 and 45NM Core2 quad CPUs were worse value than the Q6600 which dropped quite close to £100ish at one point.
My overclocked Q6600 lasted for years and did so for many gamers.
Yet look at all the stupid dorks arguing which was one was better due to the "maximum overclocks argument" and 5% more IPC,whilst running FPS counters comparing which FPS is better FPS. In the end the Phenom II and 45NM Core2 didn't really outlive each in terms of lifespan.
Its like buying a GTX1080TI to last 5 to 6 years - in most cases with computer tech its just better if you buy a bit cheaper and upgrade a bit more often.
