Caporegime
 - 18 Sep 2009
 - Dormanstown.
AMD are the saviour of the enthusiast universe and massive underdogs in this market. I think we can cut them a little slack.
Wow.
I don't know what you mean. I gave you an example of another retailer that doesn't do what you say, plus phrasing it as "AMD advertises" and "Intel advertises" is disingenuous. Clearly it's the retailer's decision or they'd be the same on every website. Maybe we should say "boo, OcUK is misleading" in this case.@DragonQ We're talking about retailers here, AMD almost always advertises the Turbo speed in the title of their products while Intel has the base clock, check other retailers.
It doesn't even matter much, but this is mainly a shot at the whole "boo Intel is misleading" crowd in this thread.
Of course it's useful, I'd rather the current situation than have chips only clocked to 3.5 GHz because otherwise they'd blow their TDP figures. I think the main point of contention here is that if they no longer advertise all-core boost numbers, then essentially you don't have any all-core turbo. The chip could sit at base clocks and as far as Intel or AMD is concerned it's "working fine".The whole point of argument is stupid to begin with, Turbo offers some tangible performance gains and isn't just for marketing numbers, regardless of vendor.
And this whole piece of news is taken way out of proportion by a few who don't understand how Turbo works and just wanted something to bash Intel for.
It's impressive how some of the knights of AMD on this forum have made an issue out of basically nothing
It's actually mostly Intel fans and review sites complaining about it.
True.If one is disingenuous or misleading, so is the other.
I don't think you were understanding what I was getting at in my hypothetical example.Also Turbo doesn't blow their TDP figures because TDP is one of the limits, it shows a very weak understanding of what Turbo is or how it works when you say things like that, including "essentially you don't have any all core turbo", because it's not true.
I agree it doesn't make a whole lot of sense, I just can't think of another reason why they would stop giving the figures (even if it was hidden away). It's just speculation and I made that clear.Plus the whole narrative of them changing the way they bin their CPUs also doesn't make any sense, the 6C is a 180mm2 die on a very mature process at this point, they're managing to produce in volume 484mm2 and 698mm2 dies but they're supposedly having issues with 180mm2? It makes no sense.
If you're referring to me then lol.It's impressive how some of the knights of AMD on this forum have made an issue out of basically nothing
Depends on your definition of advertised - you said a second ago that they did have it on their website, albeit not prominently.1) they never advertised all core turbo
Probably, although it does mean that they could quietly drop maximum all-core turbo boost clocks without saying anything.2) this probably changes nothing for the end user when it comes to Turbo functionality
Why do you think they've decided to no longer publish these frequencies?
“We’re no longer disclosing this level of detail as its proprietary to Intel. Intel only specifies processor frequencies for base and single-core Turbo in our processor marketing and technical collateral, such as ARK, and not the multi-core Turbo frequencies. We’re aligning communications to be consistent. All Turbo frequencies are opportunistic given their dependency on system configuration and workloads.”
@DragonQ Intel's statement explains it well:
The all core turbos were never guaranteed or advertised in retail or on ark, if they did, they would be a lot more misleading than the max single core turbo figure they give.
Turbo is opportunistic as in if the power/thermal/TDP limits aren't reached, the CPU will boost its frequency on any number of cores, but nowadays in a lot of consumer applications that's not a certainty. For example, rendering or video encoding will most likely reach the TDP limit hence you might be limited to or close to the base clock in those scenarios.
Even with their older CPUs, try running anything with AVX support and see if you ever reach that all core turbo number they give.
That's a very strong endorsement for AMD. I fully support this line of thinking.
AMD literally does the same thing...
But you want to see Intel back on top right?
Yes, with my current Ryzen rig, oh lordy...
Ok so that makes even less sense. Like I said cut AMD some slack if you want a strong desktop market. If you don't then keep trying to undermine them and hamming up Intel.
I'm loyal to nobody, try me.
Do you want me to pull your last 5 days posts, including those blaming even reviewers for hating Intel ?
