- 10 Nov 2006
- Lincolnshire
Alwight thanks for that
No, just changed the cpu, everything else left the same^ did you switch to GSkill mem? I have a cpu for you but the bundle can't be completed as no memory in stock.
Awesome! Hopefully this means I'll get some good news tomorrow as I ordered my 5.1g binned cpu last Friday afternoon.
I'm going to pair this CPU with 32gb of G skill 3600 RGB memory on an Asus MH10 - for best stability is it better to get 2x16gb or 4x8gb or does it not matter? Also is this the fastest speed memory that's compatible with this CPU overclock or can I go faster? Cheers
I got the 5.1 with 8X4 gb. I really wanted to get 2x16 for stability too like you asked, and for upgradability as well. But coudln't find anything like the cas 14/3600mhz 8pack I bought. Anyway, this setup has been stable and stress tested it for a few hours. Although want to do more in depth tests.
No memory is c14 3600 xmp. My range is 3200 c14 or 3600c16. Both of these kits oc really well 3866-4k very easy c18 or 19.
3600c14 no vendor is doing. My dimms will tune down though with tweaking no issues.
Not 100% sure but I had read that 2 sticks is better as not as bad on memory controller if overclocking the ram. I went for 2x 16 3600.Ahh ok thanks. And 2x16 or 4x8gb, or does it not matter?
