According to that link it's 1 hour 2 mins away
Even more reason to stick with Windows 7 :s
That's a bit extreme but going back to 8.1 is always an option.
Is it really that bad? Currently on 7 and was going to install 10 but may stick with windows 7 if this is the case.I'm using the latest update and I'm getting fed up with it already. They're removing access to more old control panel items and have their crappy new "settings" dialogs for touch/mobile users which is just useless on the desktop. The default apps dialog is especially infuriating. I suppose when a fresh install is done, you typically don't need to tinker so much but I just hate the overall direction it's going. :/
The UI is fine. Especially the option to customise the start menu colour according to your wish. Of course, it'd be better if they increase the colours count and allow any colour to be used.
May install on to a vm first to test
