Looks excellent only thing that's throwing it for me is the large curved pipe from gpu to rad, it's spoiling the straight lines you have every where else. I'd maybe change it out for two straight tubes and a 90 elbow.
Other than that it looks great.
Upgraded from a 4820K to a Ryzen Threadripper 1920X
It's a mix of primochill advanced LRT and EK Duraclear 16/11mm (7/16") hose. I bought the primochill hose when I built the i7 system and used up the spare length I had, but didn't have enough. OCUK no longer sell it so I bought the closest hose I could get to finish it off. No idea on how the EK hose will hold up against the primochill. It looks damn near identical but that doesn't mean it behaves the same. I had no trouble with plasticiser leeching out over 3 years with the primochill, just mild staining of the hose from the coolant colour.Just a quicky, what pipe is that? I'm sorting out a "just barbs" build but i'm always worried about the unsecured hose. I was thinking of a few spring clamps but the bare barbs look really nice.
Small update on Project Water 3.0
Can you tell me, please, what fitting do i need?
I think this covers all the fittings in my loop, I also have a number of spares so I can change stuff about.
A advanced warning about Bitspower fittings they are not cheap, unfortunately I live at the other end of the country.
Thank you a lot RSR!
About the tubes, do you have an advice? I would like to use clear PET 16mm OD but i dont know what brand and what internal diameter should be....
That's not a problem, please bear in mind those fittings are bespoke to my setup so your millage may vary.
This is the stuff I use, Bitspower 16mm OD and you'll also need the silicon insert for shaping the tubing.
My basket at Overclockers UK:
How many 25mm extenders and how many 20mm do you got? The description and the codes are swapped in the list.
Also, is there any barb or compression fitting?
And... is possible to change my mind about tube, i mean the idea to use flexible tubes start to gain control over hard tubes (PETG) because its much easy for a beginner and i've read you can't use nuke solution from Mayhem with PETG. Any advice here, as well, is more than welcome.
Would be the fittings different for flexible tube?
It should be 4x 25mm and 1x20mm.
Just compression
You need to me mindful of what works with your chosen W/C setup. Yes, soft tubing will need different fittings.
My pump recently broke:/ so it was opportunity to revise my setup.
Got myself phanteks CPU block - this thing looks amazing, from the box, to quality of the block itself...
Seems massive in comparison to my previous EK EVO. RGB LEDs are implemented perfectly so you can create really nice effects.
As my case is phanteks evolv ATX with restricted top decided to go with one rad EK 360 PE in the front +3 x ML 120, front panel slightly spaced out to give more airflow. Only one 140 exhausting in the back and one at the top.
Loop bends don't make sense;] but still learning to bend PETG...
