- 27 Mar 2013
How does the apple bitrate compare to netflix, or is it not comparable? I'm not sure even on fibre that it would be possible to stream uncompressed 4k.
Where did you get Spiderman for $6?Just bought Spider-Man Homecoming for $6, connected my iTunes account with my US Moviesanywhere account, i can now access Spider-Man in 4K on my Apple TV, so much cheaper than buying it over here
Here is my iTunes library so far, that's $40 worth of films and 15 in 4K.![]()
Gone up to $7.45 where i bought it but there are a few websites selling for $6-$8 depending on where you redeem it.
http://www.ultracloudhd.com/spider-man-homecoming-uv-hdx-digital-code/
Awesome thanks!
Problem with the 4K streamed stuff, even with Netflix, is the audio.
You normally wind up with Dolby Digital even if the film is in 4K HDR, most blurays would have DTS as as minimum, often having DTS-MA, DTS-HD, Atmos, or DTS-X.
The streaming market is so far behind on the audio side of things that they still can't really compete with the physical media versions.
From memory almost every film on my Apple 4K tv states Dolby Vision if the film isn’t 4K HDR but doesn’t state which audio is being used.
Dolby Vision is just an equivalent for the HDR, my TV can do both, but will only do one of them at a time.
I have a 5.1.2 sound system plugged into a Denon AVR-X3300W AV Receiver, and that will tell me what audio codecs are being used. Dolby Digital is fine for TV shows, and it's adequate for movies as well, but it will not beat the audio quality of a good audio stream which is DTS Master Audio, or Atmos, and in most cases not even DTS alone. I don't really watch movies very often on Netflix as the audio quality isn't typically as good.
Audio quality will matter more if you have a better audio system. If you just use the TV's own audio then it will probably matter very little, or a basic soundbar probably not much to it there either.
Interesting video comparing the Apple 4K video with full UHD disk streaming. The general consensus seems to be that the Apple 4K video quality is almost as good as the full disk, but not quite. The audio will still be a bit of a sticking point in my opinion though.
I thought it was a bit dodgy selling the UV codes I didnt think they were allowed for resale. EBay did have a big crackdown on these at one point but I have seen them on there today. I know it happens but I`m surprised at that US site selling them. I can see the film companies eventually getting heavy with this practice as I read you are not meant to sell them without the original disc(s) and packaging.
That is really cheeky, selling the UV codes that then presumably become 4K in iTunes? May as well just pirate the films at that point, at least you're not lining someone elses pockets then!
agree - will they make an apple app available directly on 4k tv's ?the video is interesting to see bits of the comparisons anyway
that he did this review, since, although many consumers will not see the video, folks who are writing reviews for web sites, consumers do see, will plagiarize its comments.cost would be similar on netflix/amazon though (with flexibility/economy of a family sub)but I’m paying $4 instead of £25 a 4K film
However I think Vincent's knowledge of video codecs is limited,
when you look at/compare a static paused scene, you are probably comparing an intra encoded frame rather than an inter encoded frame, see here, these should be more faithful/accurate to the original master, than other frames that are 'interpolated' (based on motion analysis)
He did not seem to make comparison of a high action sequence lasting several seconds either, which is where I think the difference would be observed. (I just stepped through video - did I miss it ?)
Has he made any comparison with the other streaming services ?, I would expect he would find them similar, since they have similar bitrate.
Apple must have likedthat he did this review, since, although many consumers will not see the video, folks who are writing reviews for web sites, consumers do see, will plagiarize its comments.
