Now you too can own a glass kettle, for £20!
Caporegime
24 Oct 2012
Yer nan's knickers
Oh yes folks, you can be the envy of all your friends and tea ladies, everybody knows that you can't beat a £200 glass kettle, except now you can!
For the princely sum of £20, Aldi will sell you one too, just grab a marker and write "Heston Blumental" on it and voila, you're in business.
You're welcome folks :D
Lidl? The link is from Aldi....
I won’t tell my other the half about this, there’s nothing wrong with our kettle but that wouldn’t stop her! :p
The money i save can go towards my next fridge:
https://www.johnlewis.com/samsung-r...Vh5PtCh1XJAPIEAQYASABEgIvVfD_BwE&gclsrc=aw.ds
I cant wait till i'll be able to check what food is in the fridge from the supermarket and set perfect curing temperature and humidity in one of the 5 separate compartments
Food management
3 built-in cameras allow you to see what’s inside the fridge via internet connectivity. When you're out shopping, you can use your phone to check what's left in the fridge and work out what you need to buy. There are also systems to help you keep track of your grocery's expiry dates, as well as monitor and re-order your food shopping.
Family connection
The fridge's touch screen display also works like a kitchen blackboard, complete with a calendar and diary for you to add reminders to, or share notes with the rest of the family. Just like a large tablet, you can watch TV or listen to the radio on while you're in the kitchen, or take advantage of a range of other apps that offer thousands of recipes and foodie ideas.
Flexible and reliable cooling
The versatile bottom-right door can switch between a fridge or a freezer with the touch of a button, allowing you to choose between 5 customisable temperature settings to suit you. What's more, the triple cooling system incorporates separate air flows for precise temperature and humidity control, so even with a full fridge, your food stays fresher for longer.
