- 28 May 2007
Far Cry 5 out this week??
According to Google FC5 is not out until 27th Feb. Think Matt was listing the games that are coming and support Vega.
Oops, no not for a while.Far Cry 5 out this week??
when I enable hbcc and click apply radeon settings restarts itself but when I check hbcc is disabled again, am I doing something wrong
Yes that works.It happens, what I did was, the first time I selected my Cache Segment and "Applied", nothing happened, Radeon Settings just closed.
All you have to do is re-open it and set your cache again, this time it should work.
Also restart your PC after doing it because for some reason it will start corrupting your Radeon Settings window if you go and resize it, after the HBCC setting application.
ok thanks will give it another go, I have 16gb ram what's the recommended setting for thatIt happens, what I did was, the first time I selected my Cache Segment and "Applied", nothing happened, Radeon Settings just closed.
Destiny 2
Doesn't work for me. I always get the 'not responding' message then it closes. Tried multiple attempts, reboots, nothing works. Have reported it.Yes that works.
Keep them coming Shanks. More and more new games showing the LC 64 competing with the 1080Ti - great stuff!RX VEGA 64 in Destiny 2 looks very close to the 1080 Ti
More to come too.Keep them coming Shanks. More and more new games showing the LC 64 competing with the 1080Ti - great stuff!
PowerColor RX VEGA 64 with 2 games £479.99 @ OCUK.
On another note members that have used EK VEGA water block are you using the supplied screws around GPU or the stock tension bracket?
That's actually a reasonable price.
