is SSL needed for SEO?
Permabanned
9 Aug 2009
UK
You should do it because it's good security practice.
These days I won't use, recommend, or link to any website that doesn't use HTTPS. So it's not just about what Google think.
6 Aug 2013
As of this month, Google Chrome has decided that credit cards and passwords aren't the only information that should be encrypted and so they're going to show a "not secure" warning on any pages that contain user data entry, and all pages viewed using HTTP in incognito mode. Even if not required for SEO purposes (though it definitely does help), it's worth considering the effect this may have on your users - I know some of ours would be put off by it.
As a side note - Plenty O'Toole is right that you can get SSL certificates online very cheaply, but installation normally needs SSH/root server access - if you're on shared hosting it's extremely unlikely that your hosting company will give you this, so you may be stuck with whatever they offer you.
OP
12 Feb 2006
Surrey
ok just spoke to vidahost. they suggested the paid for version but at £50 per domain per year, no thank you!
luckily they have done a free version so it's now enabled, and messed up my site css. should be a quick fix and now my sites SSL enabled. woo to progress
17 Apr 2006
Staffordshire
Hmmm... in my view, companies should justify why they're recommending something - "Google prefer this" doesn't say much. Anyway - I see you've installed one already - the downside to some SSL certificates is they slow websites down, which is an SEO-negative. Let's Encrypt is slower than some paid options, but for free, you can't complain. If your website collects any kind of data or sells anything I'd definitely recommend it over not having one.
30 Apr 2007
Kent
To add to this; an SSL certificate should cost you no more than £7/year, don't get ripped off.
Where have you got certificates for £7/year? I'm with TSOHost and they would still charge £25/year to manage the certificate.
What are the advantages/disadvantages of Lets Encrypt certificates vs paid ones?
25 Oct 2002
How does who signs your SSL certificate have any impact on performance?
1 Nov 2007
England
This is just incorrect. All SSL certificates of the same cryptographic strength have the same performance impact on a website. Obviously having to encrypt data does take some CPU power but but what with Intel CPUs having the AES-NI instruction set it is all done in hardware and so is incredibly fast (I believe AMD have something similar on their CPUs as well).
Pho
Pho
18 Oct 2002
Derbyshire
I don't know what TSOHost offer in terms of different SSL options and pricing but I can guarantee you'll be hard-pressed to find cheaper than Namecheap.
https://www.namecheap.com/security/ssl-certificates.aspx
Realistically you don't need a premium SSL certificate (i.e. EV or above) unless you are serious about commercial use. Small e-stores will get away with just DV.
Most hosting providers based on WHM (cPanel) will very likely issue you a DV SSL for free as it's quite literally a couple of clicks for them now. I think with a recent update the customer can do it from the cPanel update too but I've not yet explored that feature.
They're slightly cheaper via https://www.ssls.com/ssl-certificates/comodo-positivessl - especially if you go for the 3 year version. As it happens, namecheap also own them.
We've been using PositiveSSL for a few years but weirdly since migrating our app server over to Server 2016 the other weekend we had problems with our Android app on older versions (KitKat). The apps were throwing SSL handshake errors. What fixed it instantly was switching over to using let's encrypt instead. Free really is better :p
For anyone running IIS on Windows, Certify the Web makes integrating let's encrypt insanely easy. Free for up to five sites :).
8 Feb 2011
I would really want to see some hard evidence of the SEO benefits of SSL. Have there been any studies done? My sites don't take payment details or anything like that. The only user data would be cookies etc just for a more personalised user experience on the sites etc. I have a conundrum as one of my hosts doesn't offer SSL! (Yes I know, poor service but it's just an old add-on service from my Internet Provider which costs next to nothing). Changing hosts however would be an absolute nightmare for a well established website.
Sgarrista
Commissario
9 Aug 2013
Bromsgrove
Google has been using HTTPS in its ranking signal for 2-3 years now.
