HBCC does not have the same performance penalty, thankfully.I did edit above, system RAM is far slower than VRAM and only there in case you run out like a Swap/Page file, you do not want this to happen.
Try out HBCC yourself and you'll see.Well system RAM is still system RAM and VRAM though meant to do a different job is still a lot faster.
I thought you already had a Vega or did you just sell the Fury? I have a 470 in my miner rig and iv tested in games its actually a pretty good little card. It will run everything at 1080p just fine but make sure its running at the rated clock speeds by adjusting power usage and or fan speed because they can be buggers for downclocking.
First Battlefront was really cool after all the patches and new maps were finally out but it should have been like that from the start. I expect this one to be great from there start. One can hope.
    I'm definitely expecting Battlefront 2 to be one of my preferred games in 2018, Battlefront 2, Metro Exodus and State of Decay 2 FTW
.I guess someone will ask what High Bandwidth Cache is >
You might want to watch the video i added to my earlier post.
24GB + 8GB = 32GBMost i can apply is 24GB of HBCC giving me effective video memory capacity of 30GB.![]()
Lol, oops.24GB + 8GB = 32GB
Don't worry, adding really small lists of really small numbers can be tricky...Lol, oops.
That's speculation based on the Forza 7 improvements, it might not be the case with all games. Some may see little or no improvement. Maybe it's why Nvidia were late getting drivers out because they're struggling to optimise with Vulkan.ComputerBase retested their scenarios with Async for AMD, very limited gains, especially during taxing scenes.
https://www.computerbase.de/2017-10/wolfenstein-2-benchmark-async-compute/
We are still waiting for game ready drivers from NVIDIA as well, those should help add some nice gains.
The only thing i can find regarding it is in event viewer. All it says is "Display driver amdkmdap stopped responding and has successfully recovered."
Before HBCC didn't cards try and use system ram anyway for extra frame buffer? How does HBCC improve this process?System memory, right? I enabled 11.7GB of HBCC (system memeory to act as a frame buffer). I have 32GB of system memory which can be used to supplement Vega's 8GB of HBM.
This game is nothing great, the first two were better looking and less launch issues.
Not all users on steam reporting issues are Nvidia users.
Are you overclocking? Under voltage? This error is the biggest issue of a GPU that has failed its overclock.
	Surprised to see 1080 Ti still hold performance king in all resolutions.
How really very embarrassed to see what Rapid Packed Math can do to games, absolutely useless and massive waste of time. What a failure.
Look like big poor Vega for a AMD sponsored Vulkan title RTG used most advanced and very expensive newer utter useless technologies like HBM2, HBCC, Rapid Packed Math, Deferred Renderer, Primitive Binning etc that would still not able to outperformed big Pascal in 2017 and upcoming little Volta and big Volta in 2018.![]()
Everything at stock, only started happening on 17.10.2. No issues with Rainbow Six Siege on 17.10.1. Wolfenstein doesn't play nicely whatever driver i use.
 I always known driver crashes related to bad overclocking. Something else is going on here! Have you tried changing some settings in Wattman? Maybe try adding %20 on the power level or 50% maybe the GPU needs more power from the PSU?Ultra settings are not the highest visual settings, there is another tier above it. Also these numbers are apparently bogus, no other site has the difference so wide. Joker is at it again. Also he didn't do the numbers himself, he just sent it to another tech savy guys (in PresentMon form), so .. !VEGA 56 vs GTX 1080 Lol No competition...
