Caporegime
- 21 Jun 2006
mission starts around 3 minute mark.
you can see settings used at around 1 minute 30 seconds iirc
those results are BS.
I get 90 fps constant on a 1080 at 1440p res on the absolute highest settings. Whereas they say 75. my CPU only has 4 threads also. if i was running a ryzen or coffeelake it would be even higher.
Man you told us all you get 90fps "Constant" Right away I knew this was wrong! So now you give us a video showing I was indeed correct from the outside part of the video!! Of Course your FPS is going to be very high inside... So if you was fighting outside your FPS would be even worst than it is now in the early part of the video!
So I ask again why lie? they is plenty of times your FPS dropping close to 70fps outside! Do all Missions play inside? or is they outside ones like the first mission?
These Results was't BS going by your outside run, they match quite perfectly actually.
My FPS go up to 110 in places too.
So it's 75fps minimum. I'm also running my GPU underclocked by 10 percent as it's in a very tight space and it's a founders edition with the slower ram and crap cooling.
So a aftermarket 1080 would be running a lot faster still.
Also that's the lowest I have seen the FPS. I could have cherry picked a less going on environment but I just went to where I had to go next.
Even outside I get 90-100 FPS in places
Thing is you said to us all you get 90fps "Constant" reason I called you out on this because i knew it was false info, from the footage I have seen! Now had you told me I get 90fps in door areas I would have believed you, them places are not demanding hence the reason you went from 70fps to over 100fps.
Your min FPS was 70! a farcry from 90fps constant and going up and down to 90 or 100 isn't what you said! You told us 90fps constant lol
And now you using excuses about your rig! where before you talked about how excellent your rig is!
I had to swap my decent aftermarket 1080 out for the Fe version because it wouldn't fit in the case too tall.
My MSI 1080 I can overclock it and it still runs cooler than my Fe edition at stock by 10 degrees.
I changed cases between rigs as well as motherboard and CPU. I have went a Corsair air 240.
I'll keep an eye on FPS next time I'm gaming and take a video of when I'm 90 FPS constant outside.
However it's 70 FPS minimum and I get up to 110-120 FPS maximum.
Average 90 FPS overall.
The difference between an aftermarket and founders ain't that big tbh.
http://www.tomshardware.com/reviews/best-nvidia-geforce-gtx-1080-graphics-cards,4725-2.html
Overclocked the difference would most likely be less.
Were they tested in a small case with no exhaust fans at the rear or intakes at the bottom?
I own 2 * 1080's and in the same case the MSI was substantially cooler running.
The founders edition only runs cool if you have a intake fan blowing directly into its fan.
Well that's what I have noticed.
It's a pity my MSI doesn't fit. Otherwise I would have gotten rid of the founders edition. It literally sucks
I actually would have thought the Founders edition would be more suited to that due to exhausting heat out the back unlike the AIB's who exhaust into the case. No airflow is no airflow i guess. Does the extra heat in your case not impact on other components.
Such a poor performance for GTX1070.Man you told us all you get 90fps "Constant" Right away I knew this was wrong! So now you give us a video showing I was indeed correct from the outside part of the video!! Of Course your FPS is going to be very high inside... So if you was fighting outside your FPS would be even worst than it is now in the early part of the video!
Shanks posted this one a while back.Vega 64 Vs 108TI vs 1080.
Vega 64/1080TI tied, 1080 a long way behind.
They could be videos from shanks or amdmatt for all we knowShanks posted this one a while back.
This is the one where the Vega was tested by a different person on a different PC and tweaked with increased power limit and a slight memory OC wasn't it?
Also the Vega was LC and the 1080 and 1080Ti were both founder editions (reference blower coolers) if I recall.
They could be videos from shanks or amdmatt for all we know![]()
Shouldn't we compare out-of-the-box with out-of-the-box or tweaked/OC'd against tweaked/OC'd?And again like I said last time. The out of the box performance is much, much better on Nvidia that AMD can not compete unless the user tweaks Wattman!! So its a best case scenario for Nvidia and AMD.
Well unless I like talking to myself on Reddit
This is the same guy saying I made a mistake. Dont see how though.
giantmonkey1010 5 points 1 day ago
I just looked at it, gives basically 0% performance gain you obviously made a mistake in your benchmarking somewhere Mr Joker Productions.
https://www.reddit.com/r/Amd/comments/79pkhd/wolfenstein_2_amd_hbcc_massive_gains/dp3wnmn/
I can't believe if they OC'd a watercoolled 1080Ti against a stock out-of-the-box Vega 64 AC that'd you'd be happy with those results.
But most people are gonna run their GPU out of the box. I'm sure there are improvements to be made with a 1080Ti too that you can get from tweaking.No because an out of the box vega sucks. That is my point.
How much do you tweak to level something up? Who says when it's levelled? How do they know?
Also, a different person running it on a different machine. How is that comparison useful/fair?
