- 29 Aug 2010
- Cornwall
But it's how AMD ship it, that's how they intended it (apparently).Again, the FE 10 series cooler is much better. Out of the box it automatically overclocks the GPU much higher than a poor out of the box vega GPU.
How is it fair to have one GPU that will auto boost much higher vs a GPU that will just down clock out of the box?
A simple tweak to the Vega GPU lowering voltage is enough, don't even need to touch the core or memory speed and you will gain much better performance and higher clocks just like a 10 series does.
It's amd biggest downside the stock ref cooler looses them a lot of benches.
I'm sure if you fitted a waterblock to the 1080Ti and flashed a custom BIOS to it you could gain performance out of that too.
Even AMD made it **** out-of-the-box, then that's on them. You wouldn't underclock a factory overclocked card because a factory OC was too good out-of-the-box.
