Huawei P9 Lite.
For Huawei, you add the number you want to your contacts, then viewing the contact, press the menu button then tap add to black list. This will block both calling and messages.
Huawei P9 Lite.
So I've had a little dabble this afternoon -
Really it was just to check I could parse JSON data supplied by a weather API. I couldn't... initially... but learnt how
My location is hard coded at the moment, so I need to make it use the phones location, then I'm thinking to simplify it to the next three 8 hour chunks (well, will have to be 9 hour chunks as the chunks are coming in 3 hour blocks) and then of course have it so you can set a notification in the evening for the morning weather.
My only concern at this point, is the accuracy of the weather. My weather app says it's fine now and quite nice in the morning. Changing weather API will likely mean re-writing a lot.
Anyway, we'll see how it goes![]()
**EDIT** Okay, I can see it gives rainfall in mm and if it's anything above zero it says light rain, so all those 'light rain' are like 0.1mm... looks like I might need to process my own description.
 Here's an apk.Any recommendations for an app that allows a double tap on a locked screen to unlock/bring up whatever security you have to fully unlock? Just tried a couple and neither work.
My new case requires a much firmer push of the power/lock button so reckon a double tap would be better.
anyone know of an app that will keep an eye on weather for me at a certain time in the evening and alert if x = y? such as alert only if the weather is expected to drop below freezing in the night, or it's expected to rain tomorrow etc?
yeah exactly that. as kirk would say "make it happen". we can split the profits.
Forum content discussion. Few forums down, to ask about the forum / moderationIt's out in an official capacity, but I'm a little confused as tow whether I can post a link to it?
I see one of my posts was edited to say I can't promote my own YouTube channel? Does that mean I can't post my own apps too? Why would that be? I'm supposed to raise a thread in FCD? Can anyone tell me what that is? Thanks![]()
I would imagine given the discussion and request for the app that it wouldn't be wrong to link to Google play if it's free. It is after all requested and created due to posts in this thread.It's out in an official capacity, but I'm a little confused as tow whether I can post a link to it?
  Shame as quite a few people have said they appreciate them, but I understand the reasoning, so there we are.My friend was telling me about Dark Sky and it sounds great. But don't you have to subscribe now or something? How well does it work without GPS? (I wouldn't want it rinsing my battery)Dark Sky app almost does this. The x=y part it can do, e.g. you can set alert criteria such as "temperature falls below 0" or "wind speed goes above 20kph" but you can't specify an exact time. You're limited to "at any time", "daytime", "night time".
https://play.google.com/store/apps/details?id=net.darksky.darksky
I don't use the weather alerts myself, I use the app for its next hour rain forecast widget which is excellent.
