Permabanned
- 12 Sep 2013
- Knowhere
That'll workLooking good
I’ll make you jealous and post pics of my Gigabyte AIO over the weekend![]()
there's more to unleash with your 64
Could I be cheeky and ask which pump/reservoir you use in your loop?
Sweet Tony. I get excited when I see my clocks boost past 1730. Jealous mate.Hitting the magic 1800mhz core clock frequency on the new 17.11.1 driver with 1200mv again....woop woopDamn I love this card
fast forward to graphics test 2 for peak core clocks.
Edit: Just has a wee nosey at your rig picture - looks lovely that. Don't have the spheres to go custom water - maybe in another couple of years I'll find the courage...
I know mate, the pursuit of and fixation with numbers is almost irrational most of the time but it's all part of the fun in this game...Thanks mate. I'm just anal in whole numbers, in gaming the difference between 1730mhz and 1800mhz is probs less than 2fps lol.
One for the owners tree please.
Gigabyte AMD Radeon RX Vega 64 8GB HBM2 Liquid Cooled (GV-RXVEGA64X W-8GD-B)
Welcome and on TROH.![]()
I wanted to find out what PSU's those of us here with Vega 64 and Vega 56 air blower cards are using?
Got a refund for the Alphacool Eiswolf 240, it remained out of stock for to long and I couldn't be bothered waiting any longer. So now I going to just stick with my original plan and do my first full loop.. Buy the new CPU first though.
Just catching up after being away for a while... happy to report my Be Quiet! Pure Power 10 600W PSU is still going strong even with my Ryzen 7 OC @3.85, 32GB DDR4 ECC B-die @3066, and V64 (EKWB) running at ~1730MHz core & 1150MHz HBM and a full custom WC loop. The highest system power draw I've ever seen on my power meter is 571W.
I would expect the real world speed and stability of the voltage regulation control loops varies with PSU models, and the larger output capacitors in high power PSUs can somewhat mitigate a poorer response. I may have accidentally lucked out in getting a fantastic quality PSU, but I chose it as I thought it was a good deal at £65 earlier this year. It's only rated 80 Plus Silver, but crude efficiency isn't intrinsically correlated with other quality or performance factors.
Trying out the 17.11.1 drivers, but I'm seeing core clock spikes and crashes, so far just in Fire Strike.
I'm now happier with my air reference V64 than I was with the AIO version and so far my 650 watt psu seems to handle it fine. I was worried it was starving the card as it wasn't going up to 1600 let alone the stock 1630 mhz it's meant to be at but now I think it's more to do with temps as I've improved those and it now passes 1600. I ordered an 850 watt psu so tomorrow I'll see if it's any better with that as the stock clock should be 1630 mhz. Plus I'll see about overclocking once I have that installed. You're doing really well running all that with a 600 watter.
Hi I have a new vega 64 and trying to install drivers it stops and say partially installed drive 17.11.1 and error code 1603. Any 1 help with this many thanks
Same here, 975 on state 6 and 1050 on state 7, I had state 7 at 975 as well earlier so I'm gonna have to play around with it some more tomorrow.I get ~1600MHZ at stock too with the default 1632, although mine's running 1050mv.
