- 19 Feb 2007
- Sol
Keep getting screen hangs in Elite Dangerous on the newest driver on a Vega 64, Went back to the previous driver and no more hangs.
Not a driver related but I also didn't want to create a new thread for this. So just a FYI
AMD have redone the Freesync page of there website for anyone interested.
http://www.amd.com/en/products/freesync-monitors
I DDU’d and no longer crashing in BF1, stock or overclocked.@AMDMatt
dropped clocks to stock, still getting those BF1 crashes.
And what is it with Radeon Settings Control Panel always crashing and not responding whenever I try and maximise.
I see the second issue though, don’t maximise for now Tony. I drag the window up to make it bigger and that works okay.
I am getting it with fury as well as vega.. clean installs ect.Does it pretty much all the time now since my move to VEGA.
I'm hoping AMD in future drivers implement a better clean install function that removes older registry entries etc.... so we don't have to keep using DDU.
to activate it you just need to download the driver directly from AMD and run the download while you still have the current driver installed. You will then be given an option to clean install.They doto activate it you just need to download the driver directly from AMD and run the download while you still have the current driver installed. You will then be given an option to clean install.
Well wax my butt and call me suzy, You learn something new everyday![]()
Thought it might have been the DP - hdmi converter i have but vega had native hdmi so not that.
Yeah I don't know what to try to fix it, it was a problem with my Fury X and hoped it wouldn't be there with VEGA, I guess it could be
1. Drivers
2. Win10
3. Monitor
or a combination of the above![]()
For me it's not just a annoying message, sometimes after a link failure Freesync seems to no longer be available, my refresh rate bumps down to 30hz and sometimes the screen defaults back to 800x600 and you can't set another resolution, the only thing that will fix is a reboot.
