Nice to see Halo 3 is enhancedAlthough not sure if the master chief collection version is covered.
So is it worth buying halo 3 on disk? I go past a CEX on the way home and it's only for quid.Halo 3 MCC is separate code. It is native x86 rather than PowerPC so it will be getting patched differently when the whole MCC gets revisited for X1X later.
I have the old xbox one. Any point in upgrading to the Xbox one X if I don't have a 4K TV?
I'm not. Money going towards 4K TV first. You'll get some benefit from owning the X1X with a 1080p TV but not the entire experience (4K+HDR).
Sorry four quidFor a quid yes. But otherwise probably better waiting for the MCC to be updated to 4K next year, IIRC.
Sorry four quid
It's probably what I will do too, but, I like new stuff!!
I always thought they went downhill after Combat Evolved with each one getting progressively worse.I daresay I'll pick them up again to try when they get to 4K.
I think people are too busy downloading the patches/updates and playing them.And has nobody still not uploaded any 4K DVR clips to Dropbox or somewhere yet?
OK after downloading halo 3... If it's enhanced is the download part of it? Or are updates separate?
Yep, got mine on order with Very for delivery on 18th.
My PC will kick it's arse in terms of performance, but I'm still getting one. I sold my Xbox One S (mainly used as a UHD blu-ray player) and have pre-ordered Battlefront II for One X, even though it's £10 cheaper on PC and will probably run better.
I just can't be bothered playing multiplayer against keyboard and mouse people now - Xbox controller is a more level playing field![]()
I have a pretty decent PC and i just bought an X. Like you i thought it was a bit silly but did it anyway. I'm a HUGE madden fan and you cant get it on PC for some stupid reason.
