Much better for all file types, really? Anyone would think Lightroom was made by a bunch amateurs who hadn't been dealing with these files since their very inception.Capture One, it is much better than Lightroom for processing RAW files of any manufacturer.
Im not saying C1 doesn't have some advantages, LR has areas they definitely need to improve, but it's not like LR is crap or isn't used by award-winning pros the world over.
I have researched this and found numerous articles showing that the differences are there, but possibly overstated.
Example 1: http://4bcokm12bvu948gi7312gnab-wpengine.netdna-ssl.com/wp-content/uploads/2016/Lightroom vs Capture One Pro.pdf
Capture One’s philosophy is to produce a more optimized look that doesn’t necessarily require further editing. This may have led to the perception that Capture One is sharper and punchier, but in reality neither program is inherently better than the other when it comes to actually working on your images and adjusting the settings to suit individual tastes. I am disinclined to criticize Capture One’s approach. If Capture One customers find the optimized approach gives them the end result they’re after quicker, are they wrong if they happen to like what they see? Capture One certainly has the professional-level tools to produce great-looking images, but Lightroom users shouldn’t be sidetracked by claims for Capture One’s superiority. Fundamentally, the two programs aren’t as different as some might have you believe.
Capture One vs Lightroom: Should you switch?
Read more at http://www.australianphotography.co...ghtroom-should-you-switch#TbbJBM6SGMegQcQm.99 http://www.australianphotography.com/photo-tips/capture-one-vs-lightroom-should-you-switch
As far as actual image quality is concerned, I call it a draw too. Both apps process differently, with different priorities but as far as sharpness and tonal smoothness is concerned I judge them quite equivalent.
In my mind, Capture One Pro is definitely the more sophisticated package of the two, but the sheer usefulness of Lightroom is hard to beat. Unfortunately it’s not really that easy to use both together but, if you wanted to, you could conceivably use Lightroom as the master catalogue and Capture One as the specialist tool for difficult situations, exporting adjusted 16-bit TIFFs to a Hot Folder to be automatically Imported into the main Lightroom catalogue.
Is Capture One Pro V9 worth the higher cost? Yes, clearly. After all, it’s a much more powerful application and you do get what you pay for. But only if you need the extreme depth of the adjustment features. Lightroom will do 90% of what you need in a production environment but Capture One does allow a much more subtle touch and has tools that have no equivalent in either Lightroom or Photoshop.
Having said all that, I think I am going to download and try it and compare it to LR so I can make my own mind up... I'm not a pro with LR so although I am used to it, I could potentially re-learn and switch if I had to.
