You would think such people would know what an ellipsis looked like...I can only assume OP is really wishing he hadn't bothered because he's realised buying a house is reserved for people with at least a modicum of intellect......
Here's a good example of what the OP is trying to say.....
https://goo.gl/maps/hnoLASnDWNL2
That's a recent development that i dealt with. All of the plots have visible 'drain covers' for inspection into both the foul and surface water drainage before they reach the main road some on lawns, some in gravel and in one plot, on the earth where it hasn't been finished getting landscaped. By building regulation standards any manholes have to be located within the plot boundary so its quite frankly impossible for there to be no visible 'drain / drain covers' in his own house plot without the developer being breach of the regulations.![]()
Maybe you missed what the other guy said.
Are those houses built like that in case of flooding , looks weird having the door 2 foot higher than the ground.
So have they all been built on the cheap or something? Half the gardens have the lawns looking a bit naff because of these inspection covers being fitted in the middle of the grass, they've all got the front doors raised and they seem to have these white lines down the sides of the exterior walls - like someone has put them together with a kit - presumably there wasn't much bricklaying involved!
Isn't meant to insult you personally but those white lines/movement joints and this idea of a timber kit rather than brick laying does sound like a cheaper option.
yeah, why are other builders able to manage to build houses with wooden floors without a ramp up to the front door?
p.s. to whom suggested soakaways, they don't work anywhere. They need the ground to be permeable, so anywhere clayey is virtually impossible to get them approved or work even.
They don't built to NHBC Standards
Building regs require min 150 mm sub floor ventilation, NHBC require 250 mm so they will sit higher up.
Telescopic vents allow the floor to sit lower. They havent invented them up in Scotland yetyou're the expert here, I don't work in the building trade, but are you really saying that all new builds that don't have a big step up to the front door or a ramp are basically not adhering to NHBC standards? Are they not able to just dig deeper foundations and incorporate the sub floor ventilation below ground level with vents suitably positioned or something? Because I've seen plenty of new builds this side of the border and none of them seemed to need to be raised off the ground like that or have inspection covers ruining the front lawn, thus I supposed these houses were done on the cheap.
I would guess if they built the subfloor below ground level there would be issues with water ingress...you're the expert here, I don't work in the building trade, but are you really saying that all new builds that don't have a big step up to the front door or a ramp are basically not adhering to NHBC standards? Are they not able to just dig deeper foundations and incorporate the sub floor ventilation below ground level with vents suitably positioned or something? Because I've seen plenty of new builds this side of the border and none of them seemed to need to be raised off the ground like that or have inspection covers ruining the front lawn, thus I supposed these houses were done on the cheap.
Telescopic vents allow the floor to sit lower. They havent invented them up in Scotland yet![]()
If its in a flood plain thats fair enough, but periscope vents don't usually allow water to flood your floor void...As above, due to any excess water we'd rather have a bit of cushion before any water gets inside the subfloor. Whats the point in having a damp proof course when you've got a periscope vent below it which will allow water to flood in![]()
sorry to jump in but usually the covers lift off but the surrounds should be screwed or bolted down to the concrete bed of the drain. You must have drains for your waste and rain water and sometimes toilet, sink and waste depending on how strict your region is.Two issues, the first being that I was told there were no drains but can't prove it as the only ones with the plans showing it is the developer who won't let me see it. Probably because they know they are wrong.
The second being that if they are meant to be there, they aren't actually installed and are simply resting on top.
They are resting on top and aren't actually fitted to anything, that's the issue. You could walk along and take the lid off and walk away with it if you wanted. Though the main issue is that I was told that we had no drains etc...
"Sorry to jump in having not read any of the thread..."sorry to jump in but usually the covers lift off but the surrounds should be screwed or bolted down to the concrete bed of the drain. You must have drains for your waste and rain water and sometimes toilet, sink and waste depending on how strict your region is.
You are entitled to know this as any fault with the drains on your property is at YOUR expense.
Ask PERSIMMONS to supply you with the water and drainage schematics for your property.
