Alloy wheel protectors
nas
nas
2 Apr 2009
Do these actually work? I've seen a few cars with them now in blue/red which are an eye sore, but I'm days away from having my wheels refurbed in gloss black and now seriously considering having them fitted in a more suitable colour.
For reference its these (or its equivalent) which is pretty good value given the alleged level of protection it offers.
Vids can be found on youtube
17 Nov 2005
The Rimblade ones are just stuck to the alloy using 3M tape.
The better version are alloygator as they hook over the alloy edge, I had a set years ago and they were great easy to fit and lasted years, We had some fitted to another car earlier this year and have had to go back a few times for them to refit the passenger front wheel the last time we took it back they said they have had a lot of issues and think the materials or design has slightly changed and have infact stopped fitting them now.
nas
nas
OP
2 Apr 2009
Will check these out and see how they look.
25 Nov 2004
Alloygators are the ones. A hard plastic material. I have RimBands on mine which are similar, they fit under the tyre and over the alloy edge but are made from a soft rubber. They have protected my alloys (Since fitting them I just learnt to park better :p) but they have discoloured badly and look gash now. Getting them removed soon.
20 Aug 2008
Stafford
Maybe the best option is learn to park properly and you won't need to waste money on that tat on the car. Never had issues parking as I am careful not to scratch the rim of the wheel. The wife on the other hand has wheel rims like shark teeth......
Man of Honour
4 Jul 2008
sometimes it just happens, even if you're a god at parking. Or sometimes you need to take evasive action in a narrow road and it might be a choice between a collision or an alloy scuff.
nas
nas
OP
2 Apr 2009
lol theres always one
16 Nov 2014
My tyres have rim protection on. If you park slowly, you hear the tyre rubbing before you chunk the wheel.
Goodyear F1 Asymmetric 3's
