Lorries use diesel because it's cheaper to run them on it.
And why is that as the fuel is no cheaper
Is because a diesel will do more work for the same cost, its just far more obvious as the weight goes up
Have a look at some of the old range rovers petrols vs diesels for example
Anyway, was googling a bit over my canteen supplied fake Nandos chicken lunch, turns on the AA did a bit on this area a few years ago
- Getting stuck in a traffic jam is another daily problem with winter driving. Even with a warmed-up engine, a petrol car can lose at least two-thirds to three-quarters of a litre of fuel every hour, or 1.2 to 1.4p a minute. A diesel car can lose a third to half a litre of fuel an hour, or 0.6 to 1.0p a minute.
May even be a little more than Foxs' 5%
Ignoring the cost although costs are currently quite similar actually per litre of fuel, its quite clear that diesels will use less, every test indicates they do, just the numbers will vary.
few other interesting snipets we all knew but they at least tried to measure:
"Warming up an engine's oil in cold weather and greater use of heaters, windscreen wipers and lights account for the three per cent increased engine workload. Even at relatively mild winter temperatures, the fuel consumption of a cold car leaving its driveway is 40 per cent higher than normal."
- Even at a relatively mild outside temperature of +10C, a car's fuel consumption for the first mile will be around 40 per cent higher than with a warmed-up engine. This falls to around 16 per cent over the next three miles and, even up to 6.5 miles from start-up, fuel consumption can be 8 per cent higher.
This I am more surprised at frankly, I never would have said 40%!
But they broke it down a little more
The increase in fuel consumption due to cold weather is similar for both diesel and petrol cars. AA tests show extra fuel use after 1 mile and 3 miles respectively are:
- typical small petrol car – 34% and 17%
- medium petrol car – 38% and 16%
- small diesel car – 32% and 12%
- medium diesel car – 43% and 18%
Quite interesting how significant they made out the impact to be. Just goes to show how significantly down on MPG the cars are. Throw in the extra work for demisting and heating and you can see why MPGs drop for the winter season!
http://www.theaa.com/motoring_advice/news/aa-fuel-for-thought-increased-cost-of-winter-motoring.html
