- 18 Oct 2012
But most balancing of the sexes occurs on the basis that men's and women's intelligence is equal. There are many jobs that are still virtually exclusively male or female, and although slowly moving towards being more mixed, are still largely single sex.
I agree with the latter half of what you're saying, and that's presumably why they'd tailor the testing to only be the strongest women, surely?
it's not about intelligence, if it were then the test would reflect that. it's about making sure that the people you're relying on to be top tier military bad-asses can meet the extreme physical endurance that will save their lives in the field.
in general day to day the sas doesn't need the extremes they test to operate, but the test isn't about the day to day the test is about trying to simulate the very worst situations you could find yourself in in a warzone so that if it happens you'll be ready.
Then it depends on exactly what scenario you're putting them into, surely. I would imagine that the requirement for men, at least in part, are so high to ensure that they get only the best. Endurance isn't necessarily reflected by how strong you are, either, and I guess that endurance is a strong criteria.
Honestly, I just don't think that you need to be super strong to be in the SAS. It just helps them select men.
the problem with the military is you don't always get to choose the scenario you're putting people into, after all if you could choose the scenario then they'd choose the "sit back and press the magic kill all the enemy button" option
