Do you use a surge protector with your x?
Microsoft issued a statement as they can cause problems with the console.
Any further info or a link?
http://www.gizmodo.co.uk/2017/11/dont-plug-the-xbox-one-x-into-a-surge-protector-says-microsoft/ I posted this a few pages back, was asking whether anybody is using one or not as I have always used surge protectorsAny further info or a link?
I have one with the exact same feature, but i always have that switched off anywayMine was on a green energy saver / surge protection board. Couldnt get my x1 to even boot properly as it kept turning itself off. Its one where when you turn the tv off it kills the power to all the other plugs. Every time the screen goes dark the plug board clicks like its knocking the power off the tv is on but it temporarily kills the power to everything else for a split second. So in the end I found the override toggle switch and turned off green mode and not had any issues since.
Anyone know any decent puzzle style games for xbox? I bought Turing Test for my other half and she is quite enjoying it. Wanted to get her the Talos Principle too but strangely it isnt available on xbox store.
So Im looking for suggestions. Nothing fast paced, though, as she isnt great with a controller!![]()
I have the Plantronics 800LX by the way.
I'm not much of an audiophile really but they are comfortable for long periods, the battery lasts ages and the sound does seem very good to my tinnitus riddled ears.
I think that is because it was never released.
That might explain it then!!
Strange for it to be on PC and not xbox though.
Yes I do! Will try plugging it into the wall then.
