I assume the smiley is because I folded and bought one![]()
haha indeed. I'm not sadistic enough to laugh at the fact that you are having issues
My understanding is, when you opted in to beta, it was only for the 8.1 beta, then I think you carry on as normal. I would stay put. I heard the DP2 was basically what was being released now anyway.
Mine appears to be slow as hell using the included charger for some reason (13% in half an hour).Does anyone here ha
ve issues getting this device to fast(er) charge from a normal 2.4a charger? I can fast charge using the supplied usbc charger but when I try any normal charger it doesn't seem to go above 1.5a. My old pixel used to fast charge using a normal charger.
My experience is pretty similar to yours. Though, it starts off really slow, seems to speed up between 30% - 60%, then slows right down again. All using the supplied cable and plug. That said, with my usage, I'm getting best part of 3 days between charging, so I'm not too bothered!Mine appears to be slow as hell using the included charger for some reason (13% in half an hour).
I'm not convinced taking it off charge at 80% is going to help that much. Anyway the fast charging bits happen when battery is low not when it's nearly topped up.Talking about battery, I've taken to using AccuBattery to give me a warning when the phone reaches 80% so that I can unplug the device. This supposedly reduces cycle wear of the battery and this is something I'm keen to do after my Galaxy S7 Edge battery went downhill quickly due to what I assume is fast charging.
However, AccuBattery is already reporting my battery health as 88% despite the device being 3 days old - surely this can't be right? I know it's not going to be accurate as it just takes total mAh put into the phone, divided by the total % increase. I.e. in 6 charging sessions, it believes I've put 5,503mAh of charge which equates to 232% of charge. 5,503/2.32 = 2,372.
That's the thing though, as I've pointed out myself and has been eluded to by other members, the 2XL isn't even quick charging at low % either, from 0-20% is a real slog. I wonder is to do with heat? With the XL last year I noticed that the initial 50% the charger really hammered the battery and it could get quite hot. All that said I'm still pretty miffed that it's sold with this quick charging malarky vs wireless charging and the quick charging is no better than the average 2A charger for phones from 5 years ago.Anyway the fast charging bits happen when battery is low not when it's nearly topped up.
Indeed when I was in warm climates and stuck my phone onto a Xiaomi charger it really used to heat up and shut off a couple of times.That's the thing though, as I've pointed out myself and has been eluded to by other members, the 2XL isn't even quick charging at low % either, from 0-20% is a real slog. I wonder is to do with heat? With the XL last year I noticed that the initial 50% the charger really hammered the battery and it could get quite hot. All that said I'm still pretty miffed that it's sold with this quick charging malarky vs wireless charging and the quick charging is no better than the average 2A charger for phones from 5 years ago.
Now getting the 8.1 update OTA. This will be the production version so I'll no longer be on the beta
My Google home mini offer has arrived.
Same here! Charcoal one orderedMy Google home mini offer has arrived.
Same.Same here! Charcoal one ordered![]()
I've just had a Google search of the issue you guys mentioned with regards to charging speeds. There appears to be a number of threads in several locations including Google product help forums.
I've just done the same, allegedly, it's by design to stop the degradation of the battery, which I half suspected might have been the case. Oh well, I can live with it I guess, especially seeing as the battery does last a couple of days on a charge at a push.
