- 25 Nov 2011
- The KOP
I think it will be next week also.
Ever the optimist.Given its an AMD window.
It'll be the last days of December or early January![]()
'WHAT DO WE WANT!'
'THE 17.12s!'
'WHEN DO WE WANT EM!'
NOW!
Think I've experienced those from the 5870 when I first used display portStop Link Failures
My V64 definitely doesn't like the latest Crimson update, I kept getting black screens with the fan going 100% randomly, Only a hard reset would cure it, Went back to the prior driver and that problem is gone.
Makes me think it was a voltage issue though as it would never happen during games or anything that used the GPU itself so maybe idle voltage would drop too low perhaps ?
There is going to be some limited fps uplift here and there but nothing too major, Ryan's comments:Performance increases![]()
there are people that I saw in the comments on this video and in our post talking about 'oh finally we are gonna get the huge vega performance increase'. I hate, eh, let me just settle everybody down here: that's not going to happen. There's not a 20% increase in GPU performance that's happening with this. This is much more about features and capabilities, and UI elements, and making everything easier to use.
Will there ever be a permanent fix regarding bsod with the atikmpag.sys driver? Ive done all the temp fixes that Ive found by Googling, but no matter what driver version Im using Im still having crashes.
Everytime I get the bsod i check and it always comes back to atikmpag.sys. I have done memory tests but admittedly just the basic Windows one.I would start testing other hardware. BSOD mostly happen by failing memory so I would run some memory tests.
I'll try a full check and see how it goes. Thanks for the reply & advice !!
