Don't understand why we have to sit around waiting for 8.1 on a google device.
There is a 1% roll out of the update
Sitting at 100% for longer than usual doesn't really mean much, that could be by design and calibration of the battery counter.
IPhone's do that and drop off a lot quicker than usual after 50%.
Interesting, I've had my N6P enrolled in the beta since the beta for 7.0, never have I had to re enroll....You wont get Beta's for Android P from what it says on their Beta page. You have to enroll again for those.
Ah, I see.
It's a very impressive device for battery life though, I must be able to get at least five hours SOT quite consistently.
So the battery never truly reaches 100%?I've done some research today by fully draining my battery and testing the current, and mAh being put into the device.
From what I can tell, the system is displaying 100% charge when the battery is at 2,370mAh. Despite hitting 100% according to the system, accubattery is still showing current of 400mA being supplied and the total mAh continually going up past this.
According to the documentation on accubattery's website, manufacturers are known to play this little game and they believe it's down to the quick charge wars. It could be more likely to do with getting users to take their devices off charge before the battery is physically at 90% charge.
So yeah, charging to 80% (according to what the system is reporting) like I have been doing is actually only really charging to 70%!
The "playing song" feature on the AOD is pretty terrible is it not? Half of the time it either doesn't know whats playing, is showing the previous song, or just gets it completely wrong.
Same, never seen it get it wrong, but yes, sometimes your a way into the next one and it's still showing the last...
From what I have read, the 8.1 update does activate and enable the Pixel Visual Core without you doing anything in addition.
Visual Core is essentially Google's first custom designed co-processor for image recognition and ML.
So VC being enabled in theory will allow Pixel 2 users to take HDR+ pictures with apps that use the Android Camera API. And I would expect further OTA updates from Google over time that will continue to improve the quality of the images your camera can take.
By releasing the developer app, Google clearly wanted devs to create apps that can take advantage of the VC co-processor.
Does the fingerprint swipe to show notifications setting work for anyone else? Settings -> System -> Gestures. I've enabled it but swiping on the fingerprint sensor does nothing.
