What is going to drive the 4k disc price down ? I cannot believe manufacturing cost is much more than a blu-ray, and if the discs were cheaper they might sell more players - a virtuous circle.
Your comment prompted me to do some googling and I came across this video:Streamed from the Apple 4K TV.
I haven’t seen any 4K Blu-ray films played through my Blu-ray player that look better than when I play them through the Apple 4K TV.
The PQ difference is minuscule and unless you like paying £20 per 4K Blu-ray I see no reason why more people wouldn’t want to stream.
I know the benefit of a physical disk is that they can be sold/bought when you’ve watched them but I think the saving is worth it alone to own it forever.
Getting close to ordering an Apple 4K myself, how much are you finding yourself spending on films a month though @Clov!s
 Can you play UV films on apple TV then? Can't recall seeing anything to do with apple in a 4k box.
Your comment prompted me to do some googling and I came across this video:A fairly exhaustive comparison of UHD discs and Apple 4K shows the differences at a normal viewing distance are subtle even on a 65" screen.
I've just bought into 4K (55" OLED) and have a single UHD disc so far (Blade Runner, which looks great but cost £20 compared to £8 on the iTunes store for the 4K version that probably looks just about as good). Factoring in the cost as well as the convenience of a streaming box compared to firing up a player and loading a disc, I'm very tempted to return my new 4K player and go digital instead.
Thanks I had not heard of them, seems as though you can sign up with a USA IP address and then use in the UK.Most UV/VUDU films are transferable across all platforms with Movies Anywhere, so if you redeem a UV film and it is MA, you get it in itunes. You can play UV films on the Apple 4K TV
Unclear if you can port an upgraded (cheaper) 4K itunes movies to other services eg. VUDU 4k?
if so a much cheaper Roku 4K box could then be used (unless you have an oled and need dv)
...so can a genuine 4K code be ported with MA between Itunes and VUDU ? (ie movie becomes available on roku if you don't have an apple tv)If you want 4K in VUDU, it must be a 4K code you are redeeming. If you redeem a HD code then you get HDX through VUDU.
other -
UK members: Wildlife fans can watch Blue Planet II in the best quality ever shown on the BBC iPlayer from December 10th.
scanning it - references to 22Mb/s streaming !, but do you need a 4K comaptible Kaby PC, or a panasonic (HLG) tv, like earlier trial ?
the vudu appWhat would you be using to play films on the roku?
The issue is format support. The Streaming Stick Plus supports the HDR10 standard but not Dolby Vision, and the biggest source of HDR movies right now is Vudu, which only supports Dolby Vision. So while I own Wonder Woman in 4K HDR on Vudu, it plays back on the Roku in 4K only — no HDR. Vudu has been promising to support HDR10 for a while now, but until it does, I wouldn’t expect to watch anything other than Netflix and Amazon shows in HDR on the Roku.
