And if you struggle with it still, do both 2 and 3. Hot shower, thin it out with a trimmer and then use hot flannels to soften.I’ve learned a few things about avoiding irritation. I think if you do them all then hopefully it’ll improve! Some of this stuff is repeated information, but just my two cents:
Hope that helps! As a few other people have said, the first shave isn’t too good but the second is better.
- Thin your beard with a trimmer first so the hairs are as short as possible
- Have a hot shower and make sure you get a lot of hot water on your beard
- If you can’t do this then use a hot flannel on your face for a few minutes
- Use a shaving brush to apply the shaving soap to your face - this made a huge amount of difference to me actually, my shaved have improved dramatically after getting a brush
- Shave carefully. I have an old school safety razor type thing that everyone else has. Spin it every stroke to even out the shave
- Clean your face with cold water afterwards and then put moisturiser on afterwards
Exfoliating helps a lot too, helps give me a closer shave. And perhaps even using a pre-shave oil or cream of some sort.
Exactly. To be honest I enjoy it now, before with like an electric or cartridge it was laborious now it's fun.
