Keeper wise I'd say Buffon or Donnarumma, the former doesn't play like an 82 at all, plus the height helps out
Perrin is also great, not quite as good as Buffon but better than Donarumma imo
If you're not bothered about a formation change or playing people off chem. Martial is brilliant for me, gets goals and assists. I've paired him with NIF MbappeJesus >>>>>>> Laca
Has anyone tried TOTGS Mbappe?
Briefly, in honesty I'd just get the normal Mbappe, the IF's aren't dramatically different.
you must be racking up a serious amount of games?!
I've been just trickling away, usually 11/14 wins in the WL and 4 wins in SBs.
Has the market been coming down a lot recently that I've been completely unaware of? Checked the value of my team and it's about 100k less than last week![]()
I can't fault his NIF tbf. How is Pogba, his he worth the coins? Pogba or DDG and Kante are my only real route of upgrades for my team.
Might try Hamsik at CM instead, though, and TOTGS Andre Silva looks worth a try!Kante would be playing CM with Bakayoko CDM and Sissoko CM, so height isn't that much of an issue with my midfield. Currently using Herrera with those two and can't fault him. Neuer would require me to get a Bayen triangle, currently using Handanovic on 8 chem and he seems fine.Kante is excellent with the exception of his height, having a short midfield can be annoying at times. DDG makes great reflex saves with his feet and has good distribution, but he's not the best at saving long shots and doesn't seem to be a beast in 1v1's like Neuer. Neuer comes charging out and makes himself huge, some people don't rate him but he was good for me.
Pogba is a difficult one, if you don't make use of his strength and skill moves, he'll be wasted - he's not particularly fast either. If he was 200-250k it would be a totally different story, but he's currently 520k~!
Shielding is pretty much none existent nowIt was OP in 17 but literally you can't shoulder barge or anything now to hold the ball when clean through etc.
When I had Diego costa earlier in the game he was good at shielding the ball, although people like cavanni and lewandowski who were alright at it last year are a bit naff this year. See they leaked 88salah in the game if you believe what you see on twitter. POTM for him it seemsShielding is crap now, but you have shoulder barge when clean through, well I do anyway.
