- 11 May 2006
I've had this issue to some extent with the last three cars I've owned but its the most pronounced with my current car a BMW E92 330i (N53 engine). When I start the car cold in the morning, it runs beautifully, buttery smooth and tight, and the engine/exhaust makes a clean howling noise. However after it's warmed up or I start it again after driving for a while (say 20 min), the entire character of the car changes, the engine now feels rough when accelerating, and makes coarse exhaust noise. The effect is worse when I am driving slowly in town and even makes a rattle/grinding noise when accelerating from lower rpms. It sounds a lot like a diesel van. It's hard to say if the actual performance is being affected, but it certainly does not feel as good to drive, nor does it sound half as good.
Now the bizarre thing is that this does not happen when it is wet outside. When it's raining the car feels consistently smooth. I can even take the car for a wash and it will make all the problems mentioned above go away, until it has warmed up and dried again of course.
I've taken the car to multiple garages and they all say they don't notice any problems and that the car is working as it should. Some of them say that this is normal for BMW cars. I don't know if this is true as this is my first BMW. I've looked into possible issues with the DMF, clutch, propshaft mounts, but nothing is conclusive and all the garages tell me all these items are in good condition. It's honestly driving me mad at this point, as I really enjoy driving the car when it's working smoothly.
I would appreciate some advice on this. Is this a common problem? What is causing it?
