I often run ED without steam so feel free to send me a friend request in-game, Justinian Octavius and ask me anything you want.
I made my first trade mission tonight. Was asked to get 1x Fish. I travelled to where it was available to buy and bought one. Straight after I get an mail asking me to deliver it to a different port. Seemed a little lazy of them making me do this as the port I was now to deliver to was the same port I bought it from...![]()
Not sure but I think if you travel to a systems nav beacon and get close to it, it will update your system map with all the planets and moons.
Think it also brings up the location of mission objects.
I'm new to this also so maybe someone can clarify?
Thanks! I added you tonight, so I hope it makes it your way.
Unfortunately the mission switch went a bit pear shaped. Having scanned a nav beacon I closed in on Potriti 3 but on re-loading my save game got a message that ED couldn't render the graphics. Now I did buy the Horizons DLC a couple of days ago but appears this might have borked things up, in that I wasn't getting the option to start the game as this version but the mission generator thinks it is running. I tried to force a Steam update but that didn't improve matters. So for now I have refunded Horizons and gone back to Vanilla. A shame as it looks as though it added some cool features but for now I will persevere as is, maybe rebuy later on.
I also managed to find the first shipyard stocking a Cobra Mk3 - 349k bare bones - eek. Guess I've got a fair bit more grinding to do...
There's an option in the launcher to launch the vanilla game without Horizons, what graphics card are you running on?
The current Powerplay cycle ends tomorrow at 7am GMT - give me a buzz & I'll get you that cash in no time if you want either by winging up or you can have some Painite as I'm doing a mining speed test tomorrow as my power is the Mining Power & I'm collecting data for the focused feedback session on it. (Painite sells for 40k a ton).
With the change to engineering - does it mean if you gather enough resources for ten rolls you are guaranteed a better roll each time? Is there a catch anywhere or does this mean god level rolls for anyone patient enough to gather the resources?
GTX950 with 2Gb VRAM so would have thought that okay. The only options on the launcher were the same as after installing the base game - 32 bit, 64 bit (which I'm using) and combat training. No 2.x or Horizons option. Guess I will rebuy it and see if I can get it running as it would be a shame to lose all the additional features.
Does anyone have a recommended set up guide for voice attack?
