Caporegime
- 8 Jan 2004
- Rutland
Checked the caps on your mobo? Might well be that dying rather than the CPU.
What I mean is for other manufactures that make phones have to buy in DDR4, which then means the cost is transferred onto the buyer of said phone.PC enthusiasts represent a rather small part of the total demand for ddr4 which is being driven a lot by mobile phone sales. So a drop in consumer computer upgrades due to high memory prices is unlikely, on its own, to have much of an effect on global pricing for DDR4
I very much doubt your 2500k is borked, more likely the motherboard is broken so a replacement shouldn't be to bad.So I've had my 2500k for about 6 years and it' been great. A few months ago I was lacking a bit of umph so I went to a 4.8 overclock. Fully stress tested it and no bsod issues. The Last week or so I have been getting random bsods. I rempved the overclock bacl to default but it continued. Had one when I was clutching a win in pubg. Not ideal. And today is when it all went down the pan. I was demoing some rift games to the fam and just kept getting bsod aftr bsod which eventually resulted in a bsod loop. I'e managed to get it to boot by keeping the clock speed at the base speed but giving it a bit more voltage. But it still bsods after about a hour of prime95. I'v run the ram test and that came back fine. I guess it' time to upgrade. Hope there is a tempting boxing day sale for me !! 8700k yes please![]()
It's not what they are clocked to, it is how much voltage you are using to get there. I have a friend with a 2500k that is still doing 4.8Ghz but he is using 1.35v for that.I still have a 2500k. Clocked to 4.4ghz. any higher and you risked them dieing early.
Yes, definitely the case. 4.4Ghz is very good on stock voltage, though you could go up to 1.35v and it will still last as that is still within Intel specs. From what I've seen once you start going above ~1.35v then you start creeping up into degradation territory.oh yeah i agree. the thing is most would only clock to 4.3 or 4.4 with low voltage. if you got lucky maybe 4.5. maybe 1 in 10 million would do 4.6 with low volts. after that you had to start upping voltage. you hear of people hitting 5ghz and 5.2 ghz and everyone thinks theirs should do 4.8ghz with ease but that isn't the case.
i'm on 4.4ghz with stock volts. which is why it will last pretty much until the motherboard dies.
my system crapped out 2 months ago (2500k) after 6 years of faithfull service
went for 8700K + gigabyte aouris gaming ultra ( nice combo)
i8700 won't last for another 6 years. You know upgrade path is forbidden for you.
Overall, a fix for the moment but highly likely in 2 or 3 years you will start to regret.
If the 2500k was doing you well, what about just getting another 2500k? They're about 50 quid now I believe.
